C7 Corvette auto transmission issue
C-Vette 2017 (05-30-2018)
SO when I first start my C7 ( now has 4500 miles on it) then start out, the upshift from 1st to 2nd is scary, much hesitation but it eventually get there, all other shifts are ok. After the engine heats up a bit, all works normally.. By now I would think that GM has a solution for this????
It's been reported repeatedly via posts on the Range Device threads that the V8.6R1 has helped reduce considerably or eliminated the rough 1>2 shift issue for the A8.
Search the threads.
Search the threads.
Received 1,029 Likes
St. Jude Donor '05-'06-'07-'08-'09, '14-'15-'16-'17-'18
There are any number of threads about this known problem. Generally, some Vettes built before 11/2015 are more prone to problems and those built after that date are less prone. GM made some big improvements at that time.
At the first start of the day do a 1 to 2 to 1 shift via the paddles while stationary. This pre-fills one of the clutch pack actuators that is large and somewhat slow on the initial fill and avoids this issue. Not sure why GM hasn't updated software to do this sequence automatically at cold start since part of the fast shift strategy is a partial fill of next expected actuator(s).
My 2016 Z06 works flawlessly when this is done at the first start of the day.
The following 3 users liked this post by NSC5:
Year
Mine is a 2017 LT2 The white one in the photo.
I haven't experienced this or any other problem with my 2019 GS A8. I do let it warm up a couple minutes before starting off.
Co-winner 2020 C4 of the Year - Modified
2017 C4 of Year
2016 C7 of Year Finalist
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16-'17-'18-'19-'20
A8 in the GMC Sierra truck also jerks 1st to 2nd, mostly when cold. Mine & a buddy's does it.
Received 3,447 Likes
Received 2,639 Likes
knowing what year model, and how many miles you have will help with the answer.
My '16 with 8k miles has had a funky first change of the day since new. After that all is well. If that's what yours is doing I think we all will agree that's the nature of the beast. Some here will start there engine, let it run a minute, put the trans in "sport", and hit the upshift button to get that first change out of the way before they leave the garage. I have a long driveway, and the trans will shift to second before I get to the road way. There's probably nothing wrong with your trans, it just takes awhile to get used too.
The problem you describe is due to fluid drainback while the vehicle has been sitting for awhile and the symptom is the vehicle would not move or was slow to move at the initial startup. The revised stator shaft support assembly addresses that issue
The drainback issue was caught fairly early in production but the slow fill for the specific clutch pack actuator is a separate issue. With the harsh initial 1 to 2 shift there is no problem getting the vehicle moving in either forward or reverse after it has been sitting for some time but the initial 1 to 2 shift will be harsh.
I am surprised GM was caught flat footed with the slow fill issue because they had experience dealing with that when they first started using the Allision 1000 series in their heavy duty pickups 18 years ago. The Allision automatics are also clutch to clutch type automatics and due to their need to handle a very high level of torque under high vehicle load situations their clutch pack assemblies are large and the hydraulic actuators displace a lot of fluid. Some fine tuning was done early on to resolve some slow shift scenarios, particularly down to a lower range, to resolve customer complaints and they did a good job with it. My 2001 GMC 2500HD diesel was much improved after the update, the revised 6 speed version in my 2006 was even better and the current Allison 1000 in my 2018 is the best of the bunch. Due to their required heavy duty construction they will never shift as fast as the 8L90 but GM, in conjunction with Allision, has done a very nice job with that transmission and there is no good reason not to address the same sorts of issue that detract from the 8L90.
joemessman (05-31-2018)
The hard/sluggish shifts when cold may be fixable by resetting adaptive learning. This article may help.
