Mystery Plug
Old May 30, 2018 | 07:43 PM
Steadyasshegoes's Avatar
Steadyasshegoes
5th Gear
Default Mystery Plug
This is located under the dash of my C7 near the OBD2 port. Any idea what it is for?
Old May 30, 2018 | 08:05 PM
Kent1999's Avatar
Kent1999
Aftermarket plug. You bought your car used, I assume. PO installed something that plugs into the OBD2 port?
Old May 30, 2018 | 08:07 PM
Steadyasshegoes
5th Gear
I did buy used so it certainly makes sense. Thanks
Old May 30, 2018 | 08:19 PM
RottenII's Avatar
RottenII
Dashlogic?
Old May 30, 2018 | 08:25 PM
Steadyasshegoes
5th Gear
Originally Posted by RottenII
Dashlogic?
There was no hardware in the car when I bought it lightly used. The previous owner just may not have removed the cord.
Old May 30, 2018 | 08:29 PM
Marcho Polo's Avatar
Marcho Polo
2023 C8 of the Year Winner - Unmodified
2020 Corvette of the Year Finalist (stock)
2019 C7 of Year Winner (stock)
Former Moderator
Cruise-In I-II-III Veteran
Is there any part number or anything on it? Where does the other end connect to?
Old May 30, 2018 | 08:33 PM
Steadyasshegoes
5th Gear
No identifiable markings on it. It snakes up into the dash somewhere. I may take the dash apart and see if I can figure out where it is going.
Old May 31, 2018 | 08:49 AM
RottenII's Avatar
RottenII
All the hardware on mine is behind the plastic kick panel so all you can see in the plug and wire leading behind it. Can always plug it in and see if it does anything obvious.
Old May 31, 2018 | 10:28 AM
Flame Red's Avatar
Flame Red
Might be a OBD power adapter for a radar detector, dashcam or other accessory to power it up. I assume the prior owner removed the accessory but did not pull out the wiring.
Old May 31, 2018 | 05:36 PM
Avanti's Avatar
Avanti
If all is working correctly, why not just tie or tuck it up out of the way and go on? It's hardly worth taking"...the dash apart..." imho.
Old May 31, 2018 | 06:05 PM
Steadyasshegoes
5th Gear
Thanks everyone!
To Mystery Plug
