Is this normal? Hissing from engine bay
Old May 31, 2018 | 12:54 PM
VENOM ACR's Avatar
VENOM ACR
Default Is this normal? Hissing from engine bay
So I had the hood up yesterday after installing a new CAI. Car was idling in the garage. I also swapped new brake pads in, so I presses the brake pedal a few times to get some pedal feel. All of a sudden I started hearing this hissing or electric noise every time I applied brakes. Longer I presses, longer it went for. I took car to dealership and they said the sound is normal.
I have a video but no clue how to post it here. It's pretty loud and sounds like it's coming from the driver front wheel well area.
Out of curiosity, can anyone try to replicate this? Pop hood, start car, after 30 seconds hit the brakes and hold for like 5-10 seconds. I just want to know if it's normal or if dealership is incompetent.
Old May 31, 2018 | 07:17 PM
VENOM ACR's Avatar
VENOM ACR
So I guess I'm only person that has experienced this "normal" noise....
Old May 31, 2018 | 07:24 PM
dbirdhouse1's Avatar
dbirdhouse1
Default A first for me
have owned six Vettes including 2 C7's, have not heard that sound before but unless it is very obvious would it be heard if you weren't (now) listening for it?
Old May 31, 2018 | 07:38 PM
Cowboy26a's Avatar
Cowboy26a
Sounds like the brake booster
Old May 31, 2018 | 11:51 PM
bearphoto's Avatar
bearphoto
SoCal Events Coordinator
St. Jude Donor '12
Two possible issues. First you had the ac on and the compressor lines were dripping water onto the exhaust causing the hissing noise. Or...
You have a vacuum leak. In the case of a vacuum leak the car would be idling at a higher rpm. Stepping on the brake and hearing the hissing would tell me that the brake power booster might have a vacuum leak.
Keep up posted on what you discover.
Old Jun 1, 2018 | 12:06 AM
VENOM ACR's Avatar
VENOM ACR
Well according to the dealership this is normal. I can't imagine that's normal.
I did a search and found an old post where someone mentioned about the ABS and it's a test that it's working? Something like that.
Unfortunately I don't know anyone local with a c7 to test this out.
And no, the AC was not on.
Old Jun 1, 2018 | 11:30 AM
RonC7's Avatar
RonC7
The round shiny cylinder in front of the brake master cylinder is an electric vacuum pump. The vac pump runs when manifold vacuum is not sufficient. Multiple brake applications at idle would reasonably be a case where the vac pump runs.
I guess you could have someone apply the brakes while you feel / listen to the vac pump. Never noticed the noise, but I have not done any brake work nor pumped the brakes while parked.
To Is this normal? Hissing from engine bay
