Steering wheel problem
Old Jun 1, 2018 | 02:38 AM
Ali’s c7's Avatar
Ali’s c7
2nd Gear
Default Steering wheel problem
Good day guys,
I had a problem with my steering wheel controller which is it I moved it up then it stuck didn’t goes down again front back at all I’m wondering why!! Can you please give a solution for this is it a fuse problem or something like that?
Old Jun 1, 2018 | 03:31 AM
davepl's Avatar
davepl
Switch or a sensor is bad, and it's a trip to the dealer. Can't fix that one in a post!
Sometimes if its a limit or force switch, "helping" the steering wheel go where you want it with your hand -might- help.
Old Jun 1, 2018 | 04:55 AM
Ali’s c7's Avatar
Ali’s c7
2nd Gear
The adjustment doesn’t work hope if I can make it work manually
Old Jun 1, 2018 | 05:39 AM
cowboy casey's Avatar
cowboy casey
no manual operation
To Steering wheel problem
