Tread wear vs. alignment
I've made notes and will digest them before meeting with the dealer, hopefully next week. I should've mentioned that I do keep tire pressure at spec (30 psi cold), so that isn't an issue. Regarding the change to AS tires, these aren't available in GS sizes yet, but by the time I need tires there likely will be some on the market. If available I'll consider going with them even though it doesn't get that cold down here in S. LA, and it almost never snows.
When it does the Corvette for sure stays in the garage.
The rear is wearing well and I hope no adjustments will be needed there, especially caster. I sense no adverse behavior at all from the car--e.g. darting from uneven caster settings or pulling to one side--so I'm hoping it will be just a minor toe or camber adjustment on the front.
I'll report back when finished, and thanks again.
That's encouraging to hear that the dealership checked it at 400 miles. I suppose I ought to do a tread depth reading on all four tires, since the car's A/S Michelins I have now had on the car for 1,000 miles of wear. The car has 1,500 total miles on it now.
The tech could have checked and fixed the one toe that was In the red. Instead he spent 30/45 minutes adjusting all 4 cambers and each toe. It is also iterative, adjust a camber and toe changes etc. I have a year on the car and tire wear is uniform.
Apparently some dealers will do it without a question. It's a good idea to wait 400 to 500 miles on a new car to have all suspension parts wear in.
Tell them something like "It wanders at high speeds. Here's my desired alignment numbers (which are within the GM tolerances). Set my numbers. If the original numbers were within the GM standards, I'll pay for the alignment. If the original numbers were outside the official specs, that should be warrantied."
So far, 4 Corvettes at 2 different dealers, never paid a dime.
Tell them something like "It wanders at high speeds. Here's my desired alignment numbers (which are within the GM tolerances). Set my numbers. If the original numbers were within the GM standards, I'll pay for the alignment. If the original numbers were outside the official specs, that should be warrantied." So far, 4 Corvettes at 2 different dealers, never paid a dime.
The issue is not being within spec. It’s the very broad range allowed! For camber it’s +0.6 to -0.6 degrees from centerline. That is for all models as I recall .
In my case the Grand Sport rears were set at -1.6 degrees from the factory and the Max allowed is -1.7 degrees. The Min allowed to say “within spec” is -0.5 degrees. Think about what you would like, i.e. closer to less negative camber for better tire wear OR most negative camber if you Track etc. In my case I picked -0.8 degrees where the Tech set it. For me the compromise I wanted between tire wear and cornering. I don’t Track.
If you don’t hand them a sheet of paper stating what you want, as one poster said they put it on the machine and only one item was in RED out of spec and that is all they changed saying all good! In my case the only showing in Red was one toe. Had I not given them a sheet saying exactly what I wanted the Tech could have fixed it and said “all is good, within spec.”
If you go to a Vette alignment specialist, sure you can ask for a setting giving you better tire wear. But at a dealer it’s problematic if they will guess at what you want or if their idea is what you want. . Do your homework, pick the centerline or either side and hand them a sheet of paper. Mine showed the Grand Sport spec (which when they plug the VIN number in the alignment machine they actually have) and my request.
Don’t offer to pay at first they get paid by GM indicating customer said to cover the reson they did it on Warranty.
Frankly I’d avoid using the tire wear excess as the reason, as they can say it looks normal! If you say it “feels” like it’s pulling to the right or the “highway stability” doen’t seem right, no BS about “it’s normal.” How can your “feeling” be written off as normal. If you don’t want to fib, drive on a small cambered rural road and let go of whe wheel! The road is cambered to have rain run to the edge-car will pull slightly right!
The issue is not being within spec. It’s the very broad range allowed! For camber it’s +0.6 to -0.6 degrees. That is for all models as I recall .
In my case the Grand Sport was set at -1.6 degrees from the factory and the Max allowed is -1.7 degrees. The Min allowed to say “within spec” is -0.5 degrees. Think about what you would like, i.e. closer to less negative camber for better tire wear OR most negative camber if you Track etc. In my case I picked -0.8 degrees where the Tech set it. For me the compromise I wanted between tire wear and cornering.
If you don’t hand them a sheet of paper stating what you want, as one poster said they put it on the machine and only one item was in RED out of spec and that is all they charged saying all good! Don’t offer to pay at first they get paid by GM.
Frankly I’d avoid using the tire wear excess, as they can say it looks normal! If you say if “feels” like it’s pulling to the right or the “highway stability” doen’t seem right, no BS about “it’s normal.” How can your “feeling” be written ofas normal. If you don’t want to fib, drive on a small cambered rural road and let go of whe wheel! The road is cambered to have rain run to the edge-car will pull slightly right!
