Sensitive inside hatch release
Old Jun 10, 2018 | 12:11 PM
Jerrymannal's Avatar
Jerrymannal
Default Sensitive inside hatch release
I frequently touch the inside hatch release with my left or right knee when when getting into my C7 coup. I don’t realize it til I get the warning alert so then it’s cuss, pull over, stop, get out, close the hatch, get back in, cuss again and start again. Aside from the obvious solution of not touching the release when entering, have any forum members found a way to desensitize the release?
Old Jun 10, 2018 | 12:36 PM
Italianfox's Avatar
Italianfox
You're sitting too close
Old Jun 10, 2018 | 12:40 PM
aj98's Avatar
aj98
Enable easy entry,exit, if your model has it. It helps a lot, as it gets you knee farther away from the button.
Old Jun 10, 2018 | 12:42 PM
owc6's Avatar
owc6
I hope you never have the airbag explode in your face if you are that close.
Old Jun 10, 2018 | 01:11 PM
smurfmacaw's Avatar
smurfmacaw
He also could be tall. I have that problem sometimes. Whoever decided to place that hatch release right where the knee goes must not have been paying attention in their rocket science class.
Old Jun 10, 2018 | 01:17 PM
Red C8 of Jax's Avatar
Red C8 of Jax
Not a common problem, but does happen. Move your seat back.
Old Jun 10, 2018 | 01:30 PM
NSC5's Avatar
NSC5
I am tall and I had to adjust my "getting out" behavior to avoid this when I first bought my Z06. I haven't accidentally popped the hatch open since the first couple of months of ownership back in 2016.
I recall early on that some forum member made a little plate to go around the hatch button so that the button was recessed below the plate and that stopped the problem for him. GM recalled my 2014 ATS to do a similar modification to the sunroof switches because they weren't recessed sufficiently according to some federal safety standard.
I now feel so much safer when driving my ATS knowing that I won't inadvertently open the sunroof and go flying out while driving down the interstate.
Old Jun 10, 2018 | 04:07 PM
FKING1's Avatar
FKING1
Happens frequently.
Poor design.
Old Jun 10, 2018 | 04:30 PM
Iconic's Avatar
Iconic
Miller Time Wisconsin 🍺
2021 C7 of the Year - Modified Finalist
2018 C7 of Year Winner
2017 C7 of Year Finalist
St. Jude Donor '13 thru '22
In 3 C7s, I have lost count of how many times I have bumped that **** with my knee getting into the car.
You'd think the C7 R&D folks would have bitched about the location of this switch.
Old Jun 10, 2018 | 04:45 PM
Jerrymannal
I”m 6ft 260lbs and 76years old. I drive with the seat almost all the way back.
Old Jun 10, 2018 | 10:22 PM
Avanti's Avatar
Avanti
Since it is apparently recurring I suggest you find and practice a method of getting in that doesn't do it over and over until second nature. Then attend to it for a while as you use that method to be sure you always do so.
This same routine is used in all sorts of behavior mod practices from sports to management.
Old Jun 10, 2018 | 10:41 PM
owc6's Avatar
owc6
What kind of inseam measurements are we talking here?
I have a 34" inseam and have never ever come close to hitting the button.
Are you all basketball players?
Old Jun 10, 2018 | 10:50 PM
4thC4at60's Avatar
4thC4at60
66,000 miles on my C7 - bumped the button once....
Old Jun 10, 2018 | 10:51 PM
4thC4at60's Avatar
4thC4at60
Problem doesn't exit for most folks....
Old Jun 10, 2018 | 10:56 PM
atljar's Avatar
atljar
6'1, easy exit enabled, and I hit that damn switch about 1x a week. So annoying
To Sensitive inside hatch release
