Gas gauge
Old Jun 11, 2018 | 10:02 AM
chas70's Avatar
chas70
Default Gas gauge
I had a gas gauge on the dash quit working so I took it to the dealer and it turned out to be a sensor in the tank. To change it the tank needs to be removed. To remove the tank requires removing the differential, sub frame, transmission exhaust and the rear body panel.
To make a long story short, 3, 500 bucks later and hopefully done today, I hope it is fixed.
Old Jun 11, 2018 | 10:36 AM
Flame Red's Avatar
Flame Red
Sorry to say, but you should have tried searching here first. Sometimes, treating the gasoline with Chevron Techron - can cure the problem.
Old Jun 11, 2018 | 10:37 AM
Phanni's Avatar
Phanni
Wow,,I hope it was covered under warranty,.
C-5s are notorious for gas gauge/sending unit failures, it can often be fixed using techron fuel additive. I've been curious whether to put a bottle of techron in, on occasion, in my C-7. I do it regular (twice a year) on my C-5.
Old Jun 11, 2018 | 05:25 PM
Maxie2U's Avatar
Maxie2U
Asking those who have an extended warranty. Would this be covered under an extended warranty?
Since transmitting/receiving devices are not covered I assume the answer is no, not covered.
Old Jun 12, 2018 | 09:05 AM
bjones7131's Avatar
bjones7131
Had a friend on FB corvette group happen twice. Curious if the miles to empty displayed in inst. cluster would work if sensor goes.
Old Jun 12, 2018 | 09:08 AM
DPC57's Avatar
DPC57
On my C6, with a B2B extended warranty, this repair was covered.
Old Jun 12, 2018 | 10:07 AM
Red C8 of Jax's Avatar
Red C8 of Jax
OP what year is your C-7?
Old Jun 12, 2018 | 05:26 PM
Dcregar's Avatar
Dcregar
I hope it is covered under the warrantee, Does the DIC work?
Old Jun 12, 2018 | 07:15 PM
Jmhornz71's Avatar
Jmhornz71
I havent had the problem in MY 15 but my 96 had a problem with the gas gauge and using techron and everything cleared up and it started working right
Old Jun 14, 2018 | 02:27 AM
Grand Slam's Avatar
Grand Slam
On my C5 I would occasionally have a gauge stuck on zero after getting a bad (too much sulphur) tank of gas. After filling up the tank again the problem would go away. As everyone else has said, Techron is also the cure for many of these problems.
Old Jun 14, 2018 | 03:00 AM
joemessman's Avatar
joemessman
Sorry to read about your issue and expense. I was curious if you drove your car regularly or not. There was a recommendation made about storing C7s over the winter that to have the gas tank at one quarter full or less for extended storage. The reason being that sulfur in the gas can contaminate the sending unit. The result is what you have experienced. The reason regular driving can prevent the issue is because of the constant sloshing of gas in the tank around the sending unit. There was one Chevy dealer that had seen this issue 3 times, and they were all C7s that had stored their car over the winter with a full tank of gas.
To Gas gauge
