Did I just pick up a damaged NEW Corvette Z06?
Hello. I finally signed the deal and picked up the Z06 today. I went to dealer by taking LYFT and due to time constrain, I left without going through the entire car with dealer. When I got home, I noticed there are parts in the trunk are not installed, missing tow hook and I believe there should be a cover for battery. When the carpet is lay flat on top of the batter, it's very soft and will be pushed in easily. Then I noticed a small blemish on the paint where it connect the bumper and rear fender. So i used my finger and wipe it then the paint came off!!!
I am sure if I go back to dealer, they can install the parts, replace the tow hook and find the battery cover which I have no issue. However, the paint? Do you guys think this is just a simple paint job or possible damage to bumper and they replace and hired bad bodyshop?
I am in California and not sure what I can do now. All i can do is take back and question them but if they deny anything, what can i do. I never asked if car was damaged and repaired or not so I guess they can just say they never promised car was never damaged and there is a reason why they offer huge discount? The BIG DISCOUNT that is enough for me to get new Honda Civic EX?
Opinion and suggestion please.
here are some photos in the trunk.
Car is brand new at dealer with 5 miles showing!
Received 5,216 Likes
OMG! Sorry to see that! But, your bad for taking it out the door like that (paint issue). If they want to be asses they could claim it was okay when you left with it and you'd be hard-pressed to prove otherwise under the circumstances.
If what you got is any indication of the "new" facility's output I'm glad mine came from the old! All the best in getting it repaired properly!!!
sautan (06-19-2018)
You're not missing the cover to the battery; it's the foam piece that has the tow hook declivity it it. AFAIK, no American C7s come with a tow hook, you will have to buy it.
It's a shame about the paint. It appears that someone did a crappy job of touching it up (to try and squeeze it by a new and excited owner?). Usually, the reason this problem shows up is because the panels are too tight. It looks like you were unfortunate enough to get one that just wasn't done correctly. I'd make them fix it properly including all the panels that are misaligned (should be covered under BTB warranty).
The following 4 users liked this post by owc6:
Let us know name of Dealership and Salesman, Service Manager
so we can Email the hell out of em,,,,,,,,,,,,,,,,,,
That was a crappy paint correction.. What did they use a yellow highlighter??
The alignment of the panels sure seems like something hit it or ??
Oh and it looks like you got a crooked dealer and really didn't care about "out the door" Ready...
The following 2 users liked this post by NASTYC7:
sautan (06-19-2018),
Skid Row Joe (06-19-2018)
Not sure what is BTB and if it works in California.
Last edited by Steve Garrett; 06-19-2018 at 08:53 AM. Reason: Merged Posts-please use the Multi-Quote button in the lower right hand corner (the middle icon) to make your responses to multiple people look like this!
How many miles were on the car when you picked it up? Anyway, the problem you are seeing is very common and needs to get fixed under warranty. The body parts are interfering with each other and rub against each other thus causing the paint chipping. There are a number of threads on this issue in the Corvette Forum. I just had my Vette fixed and it has been 2 years since I purchased it new. I knew of the issue for over a year but did nothing until recently before my warranty expires. You might want to use the key words paint defects, body panel rubbing, etc to find the threads. The fixes are all over the place from adjusting the body panel brackets to replacing body panels to adding shims. Good luck.
sautan (06-19-2018)
Lesson 1: The *buyer* is responsible for checking the car at delivery time. Not the dealer — the buyer. It is a BIG purchase. If the buyer doesn’t have time — reschedule the pickup. If it isn’t important to the buyer to spend the time to do the inspection, then the little things noticed later shouldn’t matter either.
If it makes you feel better OP, you are not the first this has happened to; others have also come to the forum with the same story: “I didn’t have time/it was night time/I was tired/etc so I just quickly picked up my $70,000 car and left...later I discovered damage... what should I do?”
sautan (06-19-2018)
Shady dealer. Bad situation. Raise hell until they make it right.
sautan (06-19-2018)
Get that new ZO6, back to Montebello Chev. Pronto!
Do not leave before it's checked in for the paint and body fit problems. Show them the problem areas. They should give you a free loaner car instantly. If they deny, call Chev. 800 number and ask for help after describing the paint/fit issues.
The tow hooks don't come on Corvettes any longer, and the soft area? That's the way my battery cover is - softer.
Received 4,505 Likes
U.S. Air Force
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18-'19-'20-'21-'22-'23-'24
That's why when I was brought up, was told never buy a car in the dark.
You want to see the paint, and seams to make sure the car has no issues before leaving the dealership.
I know we are all excited and trust the dealership to have a car prep properly, but sometimes they don't do a good job.
sautan (06-19-2018)
Received 2,481 Likes
St. Jude Donor '15
"In honor of jpee"
I will say that like ptalar, I've had problems AFTER picking up a brand new car, a Corvette, and to the credit of the dealership they fixed it with no questions. That was a good dealer altho you could not tell they would be that way from their sales dept. which was not as good.
Come back and tell us how it turns out for you, and good luck.
I wouldn't go in assuming that the dealership is bad. Just be matter-of-fact: I've notice this paint issue and need it corrected. Odds are pretty good that they'll fix it, and you'll never have to get to option #2 and following.
sautan (06-19-2018)
What year car? Many cars painted in the old paint shop had this problem.
My 2019 arctic white has these very small yellow dots around the car. Its only really noticeable when I wash the car. I've been debating if I should post a thread and whine lol.
Received 19,305 Likes
'20-'21-'22-'23-'24
Approach the dealer in a calm, professional manner and ask that the paint be fixed. Warranty should cover it.
