Remote issue
Old Jun 26, 2018 | 01:09 AM
TedMI's Avatar
TedMI
Default Remote issue
I got myself a selvage C7 which is now up and running but i have a strange remote issue. When i get to the car in the morning remote doesn't work. So, I pop the lift gate and manually open the door. Of course, alarm goes on and the message center shows "attempt break in" message. After I insert the remote into the steering column I’m able to fire up the engine but i noticed radio resets as if there was no power before. if I turn the engine off and get out of the car I can lock and unlock the door with the remote with no problem. Any suggestions?
Old Jun 26, 2018 | 01:22 AM
Blu-Beast's Avatar
Blu-Beast
your remote battery maybe dead
Old Jun 26, 2018 | 01:27 AM
eboggs_jkvl's Avatar
eboggs_jkvl
Moderator emeritus
2015 C7 of the Year Finalist
http://forums.corvetteforum.com/c7-g...s-and-rke.html
Search might be your friend. Change the FOB battery.
Elmer
Old Jun 26, 2018 | 12:15 PM
self4depends's Avatar
self4depends
Cruising
Try to change your remote signal lite.May be it can work for you.
Old Jun 26, 2018 | 12:23 PM
Kent1999's Avatar
Kent1999
Elmer
99% of the time, C7 "fob issues" are the result of a dead fob battery or a weak car battery, including the times when "the guy at the auto parts store checked it and said the battery was good, so it can't be that"
Old Jun 26, 2018 | 12:53 PM
self4depends
Cruising
May be you are right..
Old Jun 26, 2018 | 03:15 PM
rsvette12's Avatar
rsvette12
Battery replacement due - been there done that
To Remote issue
