I just loaded a flash drive with music to use in my 17 GS a week ago and have been using in Corvette . It's a Lexar flash drive if it matters. I seems to me when I plug in flash drive and use Media part of radio the volume is much lower than using radio stations. Anyone have a solutions. Really annoying when switching back to radio stations and it blast me out of car. Thanks Dave
The volume can sometimes be diff depending on how you ripped the files.
Most of my music was originally mp4's and I converted them to MP3's.During the conversion,I can + or - the vol.
When I use Bluetooth with my iPhone the volume is much lower than when I use the radio. When I plug my iPhone into the USB jack its loud just like the radio is. Something about using Bluetooth it's no as loud.
Not to hijack the thread, but why isn't the volume control a relative volume instead of an absolute volume? That is, a volume setting is for the volume coming out of the speakers and not the volume change from an input.
I would bet that there are playback units that allow you to adjust and then save the volume difference between inputs.
No. It isn't that sophisticated, and you probably wouldn't want it to be.
Most songs have softer passages and louder passages, and so when you listen live, of course you don't hear everything at one volume level. Why would you want your listening in your car to be different, with the car's audio system clipping all the louder passages and boosting all the lower ones, so that everything is the same?
What others have said is correct -- fix the problem at the source. There are utilities that make this quite easy.
This is reduced dynamic range. It might make some sense in the car where there is so much background noise.
Well I have changed music from records , reel to reel cassettes and CDs to flash drive and they are all different levels of sound !!! Even different musical groups sound level is not the same !!!!! Radio sound is always louder and that's been going on for over 50 years !!! Wayne
This looks like a great program. I have a lot of music, some older stuff and lots of newer stuff. I'm constantly adjusting the volumes when playing songs from albums like "Eric Clapton's Crossroads Boxed set" or Steve Winwood's "Roll with it", compared to newer CD's and the songs I've "ripped".. During the "Rip", I had no way of knowing which albums were recorded at lower levels, so adjustments during that phase was always a "crap shoot".. With is program, it appears (if working off a thumb drive where all my music is stored), I should be able to get all those older songs volumes up closer to the new stuff, which would be a huge improvement.
Thanks for posting the tutorial and link
I just tested this w/ a thumb drive on a couple of songs. Volumes are equal to my ears. What a great program!!!!!!!
Increase the volume by using your phones volume button. The USB jack plays files directly from your music files and your cars radio decodes and plays it, the Bluetooth uses your phone to decode and play the music and is simply piped through to your speakers.
Yes it really is. I leveled the sound on my computers Music folder all at once. It had over 6,000 songs or so. It took a little while for the process to complete, but they all now have the same sound level. Glad you like it.
That's not what I am talking about. What I mean is that when listening to one source, say an MP3 playback and then you switch to another source, say XM radio, the system should maintain the same relative volume between the two different sources. If the MP3 files needed a lot of volume to hear them, you get blasted out of your seat when you change to the XM radio. This certainly isn't rocket surgery.
