Run flat
Old Jul 1, 2018 | 12:11 PM
mikeg58's Avatar
mikeg58
Default Run flat
Need advice I hit a pot hole last night and lost all air .
The rim is not damaged but it will not take air.
Tire place is closed today. It says I can drive on it for about 50 miles wonder if Just the seal was broken is the tire still good if they remove it and reseal it. Should I replace I have a 2015 stingray front tire 18” summer only. The tiers are rated for 20 k
Old Jul 1, 2018 | 12:15 PM
TEXHAWK0's Avatar
TEXHAWK0
Only way to know is to let the tire place try to reseat the tire bead and inflate... Even with new tires the most difficult part of changing a tire can be to get the bead to seal on run flats.
Old Jul 1, 2018 | 12:20 PM
c54u's Avatar
c54u
To break the seal on the bead would take a significant hit to the tire, wheel.
I would check closer to see if the rim got cracked or bent and check the alignment as well.
Old Jul 1, 2018 | 01:23 PM
mikeg58's Avatar
mikeg58
Default Run flat
Would it be save to drive car to tire place.
Old Jul 1, 2018 | 02:16 PM
Red Mist Rulz's Avatar
Red Mist Rulz
If within 50 miles at speed below 50 yes, it's safe. But the further you drive on the tire with zero pressure the more likely to are to need to replace the tire. If you have the option, you'd be better off removing the wheel and taking it to the tire shop in a different vehicle.
Old Jul 1, 2018 | 02:19 PM
tadda's Avatar
tadda
Veteran: Marine Corps
^This...
Old Jul 1, 2018 | 03:46 PM
mikeg58's Avatar
mikeg58
Default run flat
Thanks for all who responded the tire place is less then 3 miles
Old Jul 3, 2018 | 08:17 PM
mikeg58's Avatar
mikeg58
Default Rim salvaged
got the car back they were able to repair the rim
I replaced both front tires and the bothe balanced to the car Home cleaned it up and put it away 760 dollars later the pot hole was filled today. I called 311 on Sunday. The dot did act fast.
Old Jul 4, 2018 | 12:54 AM
FunDriver's Avatar
FunDriver
Does your state allow filing a claim with your Dept of Transportation for the pothole damage?
Old Jul 4, 2018 | 03:53 PM
TNSQUIRE's Avatar
TNSQUIRE
Yes but good luck getting paid. You usually have to prove they had prior knowledge of the hole.
Old Jul 4, 2018 | 05:33 PM
4thC4at60's Avatar
4thC4at60
What he said.
Had that happen on my CTS-V. Took two different tire places to locate the minute crack. Second place had a full immersion tank... partial tank was insufficient.
Old Jul 4, 2018 | 11:53 PM
Avanti's Avatar
Avanti
It is one thing to use a run-flat without air, another entirely if it is not seated properly on the wheel-bead... be very careful!
Old Jul 5, 2018 | 12:01 AM
owc6's Avatar
owc6
Meh.
Been there, done that.
Old Jul 5, 2018 | 12:19 AM
Quite the expensive pot hole. Glad you got the wheel/tires fixed.
Old Jul 5, 2018 | 01:21 AM
PatternDayTrader's Avatar
PatternDayTrader
Yeah no kidding.
​​​​​​​I don't think I would even try. It seems like a guaranteed way to ruin the wheel.
Old Jul 5, 2018 | 02:05 AM
WelderGuy's Avatar
WelderGuy
So, what was the damage to the rim, and how did they repair it?
To Run flat
