Auto window close issue
Old Jul 22, 2018 | 02:43 PM
plmmd's Avatar
plmmd
Default Auto window close issue
Two weeks ago my door was hit. Had it repainted and they took off mirror and molding etc to do so and did a great job but now 50% of the time when using auto close the window senses obstruct and goes back down. I need to raise window slowly to get it to stay up most of the time Any easy fix?
Old Jul 22, 2018 | 03:03 PM
owc6's Avatar
owc6
Take it back to the body shop and have them adjust it. I had the same problem after a deer strike. They fixed it and it's been fine ever since.
Old Jul 22, 2018 | 03:06 PM
Bcarr's Avatar
Bcarr
It probably needs reindexed. You can probably find a YouTube on it and do it yourself.
Old Jul 22, 2018 | 03:07 PM
c54u's Avatar
c54u
Try re-indexing your window.
Old Jul 22, 2018 | 03:09 PM
Bcarr's Avatar
Bcarr
This is worth a shot if you haven't tried it.
Old Nov 26, 2020 | 06:24 PM
Panfish's Avatar
Panfish
My car has been stalled in BG for almost 2 weeks on a “quality hold” inspection. This issue seems like an easy adjustment and better then a major mechanical or botched paint. They let cars like this leave the plant, but mine apparently didn’t even make THAT cut.
I can only imagine what’s wrong with mine.
Old Nov 27, 2020 | 11:18 AM
Hopefully after two years this owner has found a solution to his window problem.
To Auto window close issue
