MAG RIDE --- Yay or nay
Old 07-29-2018, 04:12 PM
laserjack
laserjack's Avatar
Default MAG RIDE --- Yay or nay
For those who may have gone from a C7 equipped with MRC to a NON-MRC C7, is this something you miss and wish it had ? Is it that noticeable ? Test rode a non-mag ride vette, and rode very smooth and comfortably. I don't plan on track driving or anything super aggressive, just cruising the coast and enjoying the car. Is it worth the $$$ as it seems to be hit and miss as I continue to search for a good used C7. I'm sure the answers will be mixed !!! thankx !
Old 07-29-2018, 04:16 PM
Foosh
Foosh's Avatar
Received 16,668 Likes on 8,311 Posts
LOL . . . no contest. MSRC is infinitely superior OEM, and it's over the top superior with a DSC Sport Controller installed. Anyone saying they don't miss it is likely just a straight-line cruiser who has no need for superior handling and chassis stability. However, even some of those recognize that MSRC delivers a more comfortable ride in the Tour setting.
The following 4 users liked this post by Foosh:
23/C8Z (07-29-2018), laserjack (07-29-2018), owc6 (07-29-2018), Pizz (07-30-2018)
Old 07-29-2018, 04:17 PM
Crossed Flags Fan
Crossed Flags Fan's Avatar
Default Save your $$$$
Had it and now I don't have. Don't miss it, don't track car, don't need it. I do drive somewhat aggressively and love taking the on/off ramps at WAY higher than posted speed and never felt like I needed it. Car rides great on broken pavement. Saved bunch of bucks and don't have to worry about the Mag ride system problems and also installing an aftermarket product (???).
Just new shocks when I need them. Have almost 50K miles on the car and drives/handles like new.
Test drive a C7 with and without and you'll know for sure which is best for YOU!!!!
The following 2 users liked this post by Crossed Flags Fan:
JerryU (07-30-2018), laserjack (07-29-2018)
Old 07-29-2018, 04:22 PM
Foosh
Foosh's Avatar
What mag ride system problems? There aren't any unless you're referring to rare reports of shock seep. However, even regular shocks seep as well, and no one even bothers to check those. There is nothing different about MSRC shock construction except the delivery of an electric current, and a different type of fluid inside. It's pretty much the same as any conventional shock.
Those leaks are caused by occasional hard impacts and even if it does happen, which is rare, they are still fully functional and will likely remain so for 100K or more miles.
Old 07-29-2018, 04:48 PM
Vet Interested
Vet Interested's Avatar
Received 2,093 Likes on 1,207 Posts
As stated above, test drive a car with and without. Then decide. The money you save not getting it can be used for something you really want....or need.
Old 07-29-2018, 05:17 PM
Kevin A Jones
Kevin A Jones's Avatar
Received 11,702 Likes on 5,595 Posts
I haven't had a C7 without Mag-Ride, however love the feel of it on the winding back roads and am sure I would miss it.
Old 07-29-2018, 05:19 PM
Bill Dearborn
Bill Dearborn's Avatar
Received 8,928 Likes on 5,333 Posts
I agree there aren't any real issues with the mag ride system. There is no need to add an aftermarket controller. However, the purpose of the MRC shock system isn't to make the car ride softer it is to make it handle better. It doesn't take a fancy shock to get the ride soft. You don't need to add an aftermarket controller if you don't want to change the system. The older cars have available GM upgrades at a cost of $350 that bring the shock calibrations up to the 2019 calibrations. You can do that or just leave it unchanged. The only downside of MRC shocks is if one goes bad the part costs a lot of money compared to a non MRC shock. However, they don't seem to go bad all that often. The old mechanically variable shocks they used before MRC shocks were introduced on the 2003 Corvettes were different. They were expensive and because they varied dampening through mechanical means they tended to fail more often.
Bill
Bill
Bill
Old 07-29-2018, 05:24 PM
Deepdiver
Deepdiver's Avatar
OP, BASED on your described needs, mag ride is not necessary....and you would not be getting good value out of the option. Save your $$ for something else..
Old 07-29-2018, 05:43 PM
white90conv
Support Corvetteforum!
white90conv's Avatar
I have a C6 with Mag Ride and on the softer setting, the ride is much harsher than the C5 and C7 that do not have Mag Ride. The handling on the C5 and the C7 is still very good in mountain driving. I value the smoother ride. I have seen other people on the forum express the view that Mag Ride makes the normal ride much harsher. I thing Mag Ride is really for people who are driving the car near the limit.
Old 07-29-2018, 06:26 PM
dvilin
dvilin's Avatar
Received 7,928 Likes on 4,810 Posts
Went to a Vette without it to one with it big difference I say get it.
The following 2 users liked this post by dvilin:
Old 07-29-2018, 07:16 PM
Big Lebowski
Big Lebowski's Avatar
Received 3,994 Likes on 1,678 Posts
I did the reverse. I drove a Stingray WITHOUT MRC for 5 hours from the Chicago area to Detroit on the way to trade it in on a new Z06. That stretch of road in Michigan is really bad, and I felt like I was going to have the fillings rattled out of my teeth. I had a lengthy road trip planned to the East coast that Summer (in my new Z06), and I began second guessing doing so. After closing the deal, i turned around and drove immediately home. The return trip, (mind you in a Z06) WITH MRC was smooth sailing. Sincerely, the difference was NIGHT AND DAY. For daily driving, the suspension adjustments are subtle...but if you plan any road trips in your C7 (and you really should) I highly recommend getting it. Consider this, if I’m not mistaken Ferrari copied the magnetic ride suspension for their cars.
Old 07-29-2018, 07:33 PM
graveyard
graveyard's Avatar
When I bought mine that is one thing I made sure it had and everone that has rode in my car has been very impressed,i love it for crusin or just any type of road you are on,my C6 had it and didn't know much about it till I started using it and you can tell a big difference no matter what anyone tells ya,i would go for the mag ride you want regret it I promise.I love mine, you will to! No it is not a absolute got to have but sure makes the ride more enjoyable,but im sure either way you will love it.
Old 07-29-2018, 07:46 PM
smajicek
smajicek's Avatar
I have a lot of c7 owners who regret not getting mag ride. I have it and don't regret it. enough said. Make your decision.
Old 07-29-2018, 07:49 PM
RCL119
RCL119's Avatar
I went from a 2016 Sting Ray with out Mag ride to a 2018 Grand Sport with Mag ride, much better with it.
Old 07-29-2018, 07:54 PM
64drvr
64drvr's Avatar
Received 1,867 Likes on 886 Posts
St. Jude Donor '15
OP, it doesn't sound like you would benefit greatly from MRC. It's great if you want the car to be multi-purpose and adjustable.
Old 07-29-2018, 08:05 PM
Avanti
Avanti's Avatar
Received 5,216 Likes on 3,459 Posts
Never miss it (nor it's leaky shocks) on the street or highway.
Old 07-29-2018, 09:05 PM
Dif
Dif's Avatar
Yay for MSRC, I wouldn't buy one without it
laserjack (07-30-2018)
To MAG RIDE --- Yay or nay
Old 07-29-2018, 09:08 PM
smajicek
smajicek's Avatar
4 years and 4 months later my mag shocks are not leaking, those c7 friends that I have that regret not getting mag were like this OP, no track, just cruisin around put put put. Now they regret not getting it. MOTORWEEK in 2014 named it the best bang for the buck.
Old 07-29-2018, 09:21 PM
KenHorse
KenHorse's Avatar
Location: I live my life by 2 rules. 1) Never share everything you know. 2)
Received 2,402 Likes on 1,366 Posts
St. Jude Donor '11-'12-'13, '16-'17-'18
Have MSRC on my '14 Z51. Getting MSRC on my GS. Wouldn't leave home without it
Old 07-29-2018, 09:55 PM
23/C8Z
23/C8Z's Avatar
Received 5,761 Likes on 3,177 Posts
the control of the car over bumpy, swooping dips, and broken pavement cannot be stressed enough. it's an amazing piece of tech. so much so that FERRARI paid for years to be able to use the tech in their car as did other high end car companies on their top models.. I had a C6 with it and my C7Z and i drove ones of both gens without it.. i would NEVER own a corvette without MSRC.. it's that good and noticeable to me
Quick Reply: MAG RIDE --- Yay or nay
