2017 GS rear tires losing pressure on a regular consistent basis. Approximately 8-10 psi per week. I can find no nails in either tire, and find it odd that both lose pressure at about the same rate.
Check to see if valve stems are leaking and check to see if there are any cracks in the rims. May have to get tires dismounted for a thorough check for possible cracked / bent rims.
There has been reports of bent GS wheels. So, that would lead me to believe some could crack also. Could be a bad seal around the lip, or bad valve stem. Maybe even something punctured the tire, and didn't hang around for you to find it. Good luck.
I did find a couple of loose valve stems on my new car from the factory. You do need an inexpensive valve stem tool to make sure the center air valve is tight. They are available at any auto part store.
