Mine was like thick zinc pasta only after 5000 mi. Full of metal particles. If it is too thick it might also affect the pump and temperature I can imagine.
Cooling fan stays on as long as the engine is running
The differential fan on on the ELSD at the left rear of the car is programmed to not run when the car is stopped. This is to avoid hearing the fan run at that location when stopped. I learned this during the factory tour.
That is what I thought. This condition did not start until I spent an afternoon on a local road track.
