Smell
Old Aug 10, 2018 | 11:14 PM
vetten76's Avatar
vetten76
My 19 still smells after two months. I’ve done everything everyone has suggested. I still have the adhesive smell.
Old Aug 10, 2018 | 11:25 PM
djnice's Avatar
djnice
What does it smell like?
Old Aug 11, 2018 | 12:52 AM
smajicek's Avatar
smajicek
Maybe it is a salvaged flood car from those flooded states like Texas etc....?
Old Aug 11, 2018 | 05:38 AM
2016C7.paul's Avatar
2016C7.paul
Mine had a weird musty smell that would not go away and then I thought of changing the cabin filter and found there was a big wad of what looked like a torn up carpet pad stuck in it. I don't know how the hell it got there but the smell is gone now.
Old Aug 11, 2018 | 09:04 AM
Near Miss's Avatar
Near Miss
Mouse house.
Old Aug 11, 2018 | 09:38 AM
Bigredwing's Avatar
Bigredwing
Originally Posted by Richard Sawkins
This weekend, I am going to remove the seats to have a look for anything under them, or under the carpet. I am a little concerned since there are air bags in the seats and I don't want to accidentally deploy one of them.
Be sure to disconnect the battery before disconnecting the underseat connectors if you decide to pull the seats.
Old Aug 11, 2018 | 10:40 AM
NSC5's Avatar
NSC5
As Near Miss stated that was done by a mouse.
Take steps now to make sure that you don't end up with more damage. They love to chew on wires. When my 2008 Cadillac CTS was two years old I tried to remote start it one morning and it briefly started and then stalled with a check engine light. A restart resulted in very low engine power and it would barely move under its own power. It went to the dealer on a flatbed and the cause was a chewed through wiring harness leading to the high pressure fuel pump. That same week one of my colleagues ended up with much greater damage to his 6 month old BMW SUV from the same rodent source.
Old Aug 11, 2018 | 01:45 PM
Rebel Yell's Avatar
Rebel Yell
I had the same thing Paul. It looked like they had the foundation started for a condo. They has also chewed up the hood liner. What a dang mess. I now keep the hood open, and rat traps along the walls of the garage.
Old Aug 11, 2018 | 05:12 PM
2016C7.paul
Originally Posted by Near Miss
Mouse house.
Ok, well that answers that question.
What is it about the cabin air filter that makes a mouse want to nest there?
Anyway, I think it must have happened in the previous owner's garage because I just checked and my filter looks brand new. Nonetheless, I am going to lay some traps in my garage just to be safe.
Old Aug 12, 2018 | 11:04 AM
aj98's Avatar
aj98
FWIW, Took my 14 about a year to lose the adhesives smell.
It is neither a DD nor is it garaged, so the windows stayed closed more than they were open.
OP, f it is a musty type smell, then along with all the other suggestions, also check the door drains. After a heavy rain, my passenger door retained a lot of water. Open and shake the door, I could hear it sloshing. Move the weatherstrip near the back of the door around, and water poured out of the drain hole. If the water level gets too high, it can leak into the interior.
Old Aug 12, 2018 | 11:23 AM
Internets_Ninja's Avatar
Internets_Ninja
If you live in a humid climate you would benefit from having the dealer enable the "Afterblow" feature on the A/C system. What happens is you run the A/C then park the car and the coils stay wet and smelly bacteria start to grow. Since it is humid the moister will linger and you car will start to smell like a dirty shoe. Afterblow makes the A/C blower of the car run for 2-3 minutes after you park your car. I think it is like if your A/C was operating for more than 10 minutes, you park the car, then after 2 minutes of being parked and shut off, the A/C blower turns on for 2 minutes to dry the condensation out of the system. Living in South Florida I've had to enable this feature on my C6 Z06 Gen 6 Camaro and now my C7.
Old Aug 12, 2018 | 11:44 AM
ByRiver's Avatar
ByRiver
Trying to justify or explain away an issue is the wrong way to do things. You are just guessing, and will usually guess wrong. Spending time in a car with a drug smell could mean it is meth car, which can be hazardous to your health. In the meanwhile those who sold you a bad sale of goods is getting away with it. Cars aren't supposed to smell. You should had found the source of the smell before buying the vehicle, especially when it is well documented that flood cars are commonly put back on the market.
Old Aug 12, 2018 | 11:59 AM
  #33
golden2husky's Avatar
golden2husky
Confirm that it is indeed a moisture related smell. That would be a moldy, mildew stink. As posted above, remove the sill plates so you can easily peel back the carpet. Any moisture is an issue. Look for whitish or black stuff growing on the padding. Check the seat bolts - are there any signs of rust? Same for the seat tracks. If you are finding any sources of water you now need to confirm is it a leak or a flood car...You can try Carfax to see where the car lived before. If the water damage is on both the passenger side and the driver's side, a flood issue is becoming more likely as the odds that both sides of the car have water leaks is not very high. Only one side? You have to track down the leak. GM cars used to be known for water entering the fresh air intake - there was a rubber gutter to divert the water and over time the rubber would fall out. Hose down the car with you inside and look for any entry points. Chasing leaks is a PITA but that's the only way...
Old Aug 12, 2018 | 02:26 PM
  #34
Null Pointer's Avatar
Null Pointer
Exception ID 10T
EZ change on a C6 with the Tech2, I did it myself. Worth having in any climate where it is humid in summer. Unfortunately, a C7 requires a trip to the dealer, and usually trying to convince them it is a feature that can be enabled using GDS2 and an MDI. Most dealers seem unaware of this feature. I wish GM would make it a DIC option.
Old Aug 14, 2018 | 08:26 AM
  #35
Richard Sawkins's Avatar
Richard Sawkins
I have a few updates. I have been thorough. This is not a flood car. There are no water leaks of any kind. The smell appears to be left over from vaping / tobacco pouches. So, it looks like a thorough steam clean is required. Tobacco odors appear to leach into everything. The smell is actually slowly getting better, I was however surprised that it returned after having the car deodorized. I don't feel quite so bad now, but at least I know more about the history of the car.
Old Aug 14, 2018 | 08:36 AM
  #36
PatternDayTrader's Avatar
PatternDayTrader
That's good news.
