2019 Base A8 Warble Question?
Does anyone have a 2019 base A8 with or without the dreaded "warble" noise which occurs in the rear differential at approx 1,500 RPM under slight acceleration? I am thinking about purchasing a new 2019 base coupe with the M7 (I miss shifting) but I currently have a '16 A8 (which is fast and the trans is flawless) and may consider 2019 configured the same way.
A simple yes or no about the warble in 2019 base A8's is all I'm looking for. Don't want a discussion about the noise, what causes it, factory fixes etc. or manual vs. auto. Thanks for any input.
Originally Posted by Rebel Yell
Scuff, the M7's do not have a warble problem that I have heard of, because of the different gearing is my guess.
I got the problem in my '16 A8, so I've done a ton of research. Luckily my warble has abated at bit, so I'm gonna drive her till she fails.
Rebel, Same here. It's there, but only a minor annoyance on my '16 A8. Came into a little bit of luck lately and was thinking of upgrading to a '19. The M7's don't have it with their 3:42 rear diffs. But all the base A8 2:41 diffs I know of, do. Was thinking of going back to a manual as I miss shifting, but I also love my A8. The warble is just one part of that decision.
I don't believe different gearing (M7 V A8) has anything to do with it from reading 8K posts on here, I didn't read them all since I have M7. It is the torque converter in the A8 locking/unlocking when the engine goes from V8 to V4 operation. A8 will go in & out of this constantly, even in town at low RPM, UNLESS using Manual paddles to shift. M7 will only go into the 4 cyl. mode if put in ECO Mode. There is the Range device (look it up-too much info for here) that is plugged into OBD port & disables 4 cyl. mode. It can also be unplugged when going to dealer for other warranty work or whatever to keep your "dirty little secret". These 2 options (range device/manual shifting A8) are by almost all posts the ticket to avoid the dreaded "SHUDDER" or RPM fluctuation.
Rob, the TQ is a whole nuther pile of crap itself. GM bought one of our members car back to investigate the warble. They found it was from the ring gear/pinion because of something being a little off. Quite a few members have had their diff changed with success. The TQ was taken cars on the cars around Nov. 15 build, and beyond. In my 03/16 build the TQ has been fine. I have no idea if they ever beat the diff supplier in line, but it seems the newer cars, i.e. 19's and maybe some '18's, are warble free.
I have a 2019 Stingray A8, and it has the warble at 1500 RPM. It's a minor nuisance, but I'll eventually get the differential replaced under warranty as others with similar cars have done recently (now that GM know exactly what the problem is). I still love my car though and have had no other problem.
I'm still waiting to hear of someone that has actually had their diff fail after having the warble noise. I still think it might just be a harmless noise that doesn't manifest itself into an outright failure. I had a set of 4.10 gears installed in my 98 Firebird Formula and the installer didn't set the gears up perfectly so they made a whining noise, but that noise never got any louder, nor did it ever turn into a major problem, I drove it for a couple of years like that, and made a few hundred quarter mile runs with it too.
You're probably correct, but even just as a bothersome sound many feel it is still desirable to have it fixed while the car is under warranty. Each owner will have to make that decision.
Remember that the problem for some cars manifests itself as a vibration like running over rumble strips, not just an annoying noise. That being said, I have asked the same question as you many times - has anyone had a catastrophic failure preceded by the warble noise or the TC issue?
Even thought it's covered under the 5 year power train warranty, my follow on question is will it stay fixed? and if not, does having it fixed during the 5 year warranty, then grandfather the problem to be a warranty claim beyond the 5 years?
True, but my issue would be that I wouldn't really like the idea of having the dealership tear the car apart if it was only for a minor noise.
Yes, I have the warble, 1500 RPM since the car was new. I now have 2200 miles, still there. I always drive in "M" mode, so no AFM involved.
I kinda like the sound, it give the car character - between the warble, ticks, hisses, rumbles, ... I feel like I am driving a sports car :-)
I would also just leave it as-is but I am concerned about long term failure.
I authored the warble post and they bought my 16 stingray back and now have a warble free 17 GS
