My driverside door now rubs against the fender when I open/close the door
2019 C7 Stingray vert. The door just started to exhibit a loud rasping sound when I open or close it. Apparently, the door is set too close to the front fender. Is anyone else having this issue?
For sure. But was curious to know if I'm the only one with this issue.
With all the rain we've had here the past several days, if it were made of wood, I could understand that it might swell and close an already tight gap, but it's plastic for cryin' out loud. Could it be that hydroscopic?? Car has under ~500 miles on it.
I would have them check the passenger door while tech is at it.
FZ1 (09-10-2018)
Absolutely. Just got in touch with the service mgr at my dealer. Appt scheduled for a week from Tuesday to get all-season tires mounted. They will check out the fitment between the door and the fender.
Received 5,252 Likes
They are called "mass produced" products for a reason. Price and compare hand-built.
EVERY part and installation is not double or triple checked at each step of manufacture or assembly. That's one reason they come with warranties.
Get it fixed. Then, ENJOY!!!
dvilin (09-10-2018)
Received 8,963 Likes
Bill
fsvoboda (09-10-2018)
im having same issue with my passenger side. I did a complete wide body conversion. No issues for the past seven months. Problem happened two weeks ago after i took off the side skirt then reattached it. Im pushing the fender with the side skirt in a way that it is not supposed to. Hopefully ill get to it soon.
FZ1 (09-10-2018)
And for the items that need it, thankfully there is warranty coverage
Received 19,473 Likes
'20-'21-'22-'23-'24
Good luck with your service appointment. Hope the dealer gets things adjusted properly.
