Look what I found in the catch can
It’s been 6500 miles since I last emptied it. So glad this gunk didn’t go into the clean side of the intake.
Let the hate begin...
The following 3 users liked this post by Maxie2U:
Popular Reply
09-18-2018, 01:26 PM
Maxie, proof works many different ways. In this case, there is no evidence of a coking problem on the LT engines, thus it would be hard to prove a catch can has any functional or significant benefit. That fact alone tilts the evidence strongly toward no benefit. No one can show any evidence of a coking-related performance problem on LT engines, and if there were you'd then have to prove that a catch can successfully mitigated the problem. You can't prove a null hypothesis, you can only reject or fail to reject it.
In the Audi, BMW, VW DI engines that suffered performance degradation as a result of valve coking, it showed up relatively early, and catch cans were not a solution. I had an '07 Audi RS4 4.2 DI V8 that needed a walnut shell cleaning at 20K miles. We're just not seeing an issue in the 6-7 years LT engines have been in use. One member who posted in this thread has well over 80K miles on her car, and we've seen quite a few over 100K miles with no issues. Obviously, GM has done extensive long-term testing, and they're not seeing a problem either. The Chief Engineer has stated such on this forum.
We've seen just about every imaginable problem on C7s reported on this forum, but engines suffering from valve coking hasn't been one of them.
Received 3,290 Likes
St. Jude Donor '12-'13-'14-'15-'16-'17
Here we go again.
The following 5 users liked this post by spinkick:
CorvetteBrent (09-19-2018),
gurneyeagle (09-18-2018),
Hey Joe (09-20-2018),
speed4tu (09-19-2018),
tdf01cycling (09-19-2018)
Received 19,300 Likes
'20-'21-'22-'23-'24
Quite a bit of oil in 6500 miles. Looks like the catch can is doing its job.
spinkick (09-17-2018)
No comment, other than amount of oil pales in comparison to the combustion by-products produced by the 325 gallons of gasoline (assuming 20 avg. mpg) you burned during the same period.
The following 7 users liked this post by Foosh:
John Micheal Henry (09-18-2018),
Maxie2U (09-17-2018),
Mike Mercury (09-17-2018),
NSC5 (09-18-2018),
owc6 (09-17-2018),
and 2 others liked this post.
I have been on four very long road trips (5000+ miles each) and all of them the CC was installed. Average MPG on those trips was between 29.7 - 30.5.
Pisswilly (09-19-2018)
I always have to laugh at the ignorance that clever marketing campaigns breed. But it also makes me feel sorry for those that are preyed upon due to their ignorance. Its a vicious cycle all in the name of making money. The ones that make me laugh the most are the Zero Ohm plug wires and the DEI catalytic converter heat shields. Although this catch can nonsense on stock motors is a close third.
NickG-Z06 (09-24-2018)
Is this a design defect for the Direct Injection Engine? That is, not having a catch can device as factory production stock? GM says you might get some discoloration on the valves but does not impact performance. I am debating putting one on my C7. I wonder if it impacts smog testing?
Valve coking comes from the extremely small amount of oil that gets past the valve guides. Everyone knows, the valves move up and down, and there is a vacuum in the intake port, therefore its impossible for valve guides and associated seals to seal perfectly. The only way it could is if the valve was seized in the guide.
Location: I live my life by 2 rules. 1) Never share everything you know. 2)
Received 2,402 Likes
St. Jude Donor '11-'12-'13, '16-'17-'18
Good luck getting good answers to this question here. It's like a religion to some who say you need one to prevent coking on the intake valves, even though nobody has ever posted a photo of such from a C7 engine. Catch cans and CAI systems have cult-like followers who are never interested in facts or objective evidence.
