The Bugatti Veryon oil change is $25K. That is more than the Corvette tax.
Quote: The Veyron uses a dry-sump oiling system with 16 different drain plugs, accessible after intricately removing parts of the underbody, which takes hours. Refilling requires removing the car's grill, rear fender liners and rear deck including rear brakes, which are bigger than front brakes.
=papillion;1598018188]The Bugatti Veryon oil change is $25K. That is more than the Corvette tax.
it's French. Also, check out a new set of tires; originally they flew over a replacement set of tires already mounted on wheels and replaced the whole works... as I recall the price was certainly more than the oil change cited here.
p.s. they did take the old set back with them, even if only one tire had been ruined and needed replaced.
It's 30k for tires and 50k for new wheels which have to be replaced every 10k miles.
