Thank everyone for the advice. I will be bring her to the dealership asap. It's my first Corvette and it's not a garage queen! i drove it everywhere and i love everything about it. But this problem is SUCK! it's killing my mood.
Your transmission may be on its way out. V4 is killing the transmissions. Start camping out at your Chev. dealer until they replace or fix your transmission. It's not supposed to be this way.
I have an M7 and have played with ECO mode out of curiosity. While not significant, I can feel it when it goes to V4 mode.
M7, here too. Stay OUT of ECO mode. Nothing good can come of running just 4-cylinders. The automatic transmission crowd here are having unbelievably bad problems even getting GM to fix their's. Be thankful that you dodged a bullet by buying the M7!!
I have a 2016 Z51 A8 with 7200 miles and going between V4 and V8 was always seamless and totally unnoticeable However, due to the threads on this forum I decided to get the Range AFM. Now I never go into V4 mode and the car seems to shift better. Mine always shifted pretty well before but seems a little better now. Not sure why, and it's not a big difference, but does seem smoother.
Don't let that issue cause you not to love your Vette. As others have said after going to the dealer and still not happy (or if they say "That's Normal") invest in a V4 defeat system!
As others have said those of us with standard shift C7s don't have to deal with the switch to V4 unless we drive in ECO. That defeat device will allow you the same. Latest info indicates they have fixed the early issues.
PS: Just put "C7 V4 disabler in Amazon." Easy plug-in install and $140 will make your $60,000+ perfect! Available from many vendors.
Let's be clear here. It's not killing the transmission. It's killing a component of the transmission called the torque converter.
I have an M7 and for long trips on the highway I will use Eco mode and the V8-V4 transition is seamless. I have no issue using Eco and have no idea why so many are against it. Ya I know you don't buy a car like this to drive it in Eco but that doesn't mean there aren't times when it is beneficial.
JD, the M7's do fine in V4 mode. It's the earlier A8's that have the problems.
It sure seams like the A8 has it's issues. I'm really glad I went with the manual.
They certainly have, and it's all across the GM models running the A8. It seems that GM trough the years always manages to come up just short of good in many of it's designs. As with many big manufacturers GM must listen to the bean counters more than they do the design engineers.
I have an M7 Z06 that I run in Eco mode most of the time when I am not on the track. The only way I know the engine switches from V8 to V4 mode is the exhaust which is set in permanent Track mode gets quieter when the engine is in V4 mode and gets loud when it is in V8 mode. When it switches back to V8 mode I can feel more acceleration but that is why it switched back to V8 mode so it could accelerate better. DOD had some valve lifter issues on the trucks that incorporated that design about 10 years ago but that seems to have gone by the wayside and is pretty much trouble free on the new vehicles.
Correct. The 2018 GMC Yukon XL has the same systemic issues.
When were torque converters considered not part of the ATs?
Go back and re-read what I posted. I said it is a component of the transmission. My point is that the cost to buy a new torque converter is a lot less than having to buy a whole new transmission. In other words a killed torque converter is cheaper to fix than a killed transmission. Folks need to know what they are signing up for.
My 2017 Stingray had no issues at all with this and got 30+ MPG on open long trips. Now my 2019 Grand Sport with less then 3000 miles is a completely different story!!! Very distinctive shake on/off 15-30 seconds, you can see it in the Tack like if it was misfiring and gets 22-24 MPG on first open long trip. My wife even looked at me and asked if the road was that rough or was it the car. Became clear after a while it was the car and only did it in V4 Mode. Dropped off and dealer Saturday, now to see what they say.
I had a 2015 Z51, and my TC problems started out just like what you are describing! Watch you tach when you are driving, and you will see a small fluctuation in the RPM maybe 50 or so RPM's. They replaced the TC on mine-twice. I would get it in, and have it checked. I understand that the current cure for this is a new type of fluid! GOOD LUCK!
New fluid which was released early in 2019 is Mobil 1 Syn LV ATF HP 124715. This was installed in our 2016 about 2 months ago with significant improvement in shift quality including the initial first to second shift when cold. Subsequent to fluid change I installed Range AFM Disabler which eliminates V4 mode. Happy with this so far. I've also got a couple of 10 oz bottles of Lubegard Platinum on the shelf which should create an improvement. By design the Torque Converter is supposed to slip 10 RPM when in V4 mode. 10 RPM slippage has to be very difficult to control. As someone else mentioned, there are many threads on this issue. Good luck.
