Battery Load Test: Two Questions
Old Oct 9, 2018 | 12:47 PM
rmorin1249's Avatar
rmorin1249
St. Jude Donor '15-'16,'18
Default Battery Load Test: Two Questions
1. Is it safe to use the positive battery connection under the hood to have AutoZone conduct a load test of my battery? I would rather not have them try to access the battery itself.
2. Is it true that a load test can actually hasten battery failure?
My battery is now just over 3 years old but is almost always on a CTEK and I have not noticed any issues but do not want to get caught in the middle of nowhere with a dead battery.
Thanks.
Old Oct 9, 2018 | 01:23 PM
50th year's Avatar
50th year
2017 C7 of Year Finalist
Get a Solar Battery tester. It will measure how many cranking amps are left in the battery. My battery is rated at 420 cca and if it falls below 300 I change it. I believe a battery needs between 150 and 200 cca to start a car.
Old Oct 9, 2018 | 01:50 PM
Kevin A Jones's Avatar
Kevin A Jones
Thanks.
I don't let Auto Zone or other retailers test my battery in vehicle, I will take it to them for testing.
A load test should not damage or hasten battery failure for a good battery so your 36 month old battery that has been cared for should be fine.
Now if you load test a a 5-6 year old battery on it's last leg even though it passes load-test don't be surprised if if dies a week or two later. Load testing does put stress on a old battery.
Old Oct 9, 2018 | 03:30 PM
ersatz928's Avatar
ersatz928
Using the underhood terminals will give a falsely low CCA measurement from a battery load tester, due to the impedance/resistance of the long cables. For an accurate reading, it should be done at the battery terminals. A load test will not harm the battery.
Old Oct 9, 2018 | 05:04 PM
rmorin1249's Avatar
rmorin1249
Originally Posted by ersatz928
Using the underhood terminals will give a falsely low CCA measurement from a battery load tester, due to the impedance/resistance of the long cables. For what a accurate reading, it should be done at the battery terminals. A load test will not harm the battery.
Thanks. This is what I suspected. I will prepare the battery by exposing the terminals. Appreciate the info.
Added: At the dealer now getting the battery load test. No charge for the test.
Battery passed load test with flying colors. Tech asked if I used a maintainer. When I told him I did he said he could tell. He said battery was as good as a new one.
To Battery Load Test: Two Questions
