Wheel full turn
Wheel full turn
I just got a 2014 Z51 Stingray and when I back out of my driveway, when I turn wheel all the way it feels like the tires are wobbly or rubbing. Does anyone have the same experience? Even when I make a u turn and turn wheel all the way it sounds like tires rubbing on body.
Lots of threads on this, don't worry it's normal for grippe tires. The outside edge of the front tires are traveling farther than the inside of the tire.....something has to slip, that's what you are hearing/feeling.
Received 2,639 Likes
Yep, it's normal. They will also skip across the painted lines in parking lots when your turning.
Every year, when it begins to turn cooler, these threads re-emerge. I noticed this weekend when the temp dipped into the 50s for the first time, they were skipping in low speed, tight turns in parking lots. The PSS doesn't do that when properly warmed up and sticky, and it's the signal that they have much reduced grip because the rubber compound is getting hard. That's also my cue for switching to my AS3+ set for winter use. They don't do that even in frigid temps.
Other cars may do it as well, but it's primarily a tire issue with wide summer max performance tires in cold weather. Summer rubber compounds are soft when warm, and hard when cold. AS tire compounds are not as temperature sensitive, and are close to equally pliable across a wide range of temps.
My C7 does not do it on the AS3+ even at temps in the single digits. Likewise, it doesn't happen on the PSS either when pavement temps are above 80 or so.
It scared the crap out of me the first few times it happened in a parking lot because I thought I hit or ran over something. Then I read the "normal things" thread: https://www.corvetteforum.com/forums...ette-does.html and tire chatter was the item #1 item on the list.
You mean you have not heard of the “Ackerman effect”. I believe that is the technical term for what you are experiencing.
green2000 (10-15-2018)
certainly normal. Get used to it! Enjoy the Vette!
I rarely have to turn my wheels to full lock on any of my vehicles,...……..It stresses a lot of components unnecessarily, Steering, tires, transmission, engine, all have to work harder to move the vehicle! Just DON'T do it.
Miya not at full turn. It’s at about 50%. I got my answer already. It’s the summer tires in the cold weather up here in the north east.
E-Ray, 3LZ, ZER, LIFT
Received 9,625 Likes
http://netwelding.com/Wheel_Chatter.pdf
It's worse when wet out- PDF shows why!
EASY SOLUTION:
In the summer when I back out of my driveway I make a full lock turn and no "chatter" as GM calls it to go down the driveway. When below 50 F and for sure at 45 F I turn the wheel a half turn less and make a "K" turn so I can go down the driveway. When it's 35F I turn the wheel even less and make 2 "K" turns! Works! Since the car is knew to you this is particularly important if backing out of a mall parking slot, needing a full lock turn and have a friend in the car. It gets so bad when colder your friend will tell all your buddies "What a piece of junk you bought"
I got my C7 Z51 in early October 2013 and there was no good explanation of why it was happening. GM's "it's normal" was not much consolation. Recall a post from that time when a poster said he was backing out of a parking slot after a late night dinner and it "Chattered or as GM also calls it Hopping" so bad he got out to look and see what broke. His wife wanted him to leave the car and call the dealer in the morning to have it flat bedded in! The PDF will at least allow you to discuss race car tire slip angels if you forget when you have a friend in the car!
Yep, a simple "It's Normal" in the Owner's Manual. They also included a tag on the shifter with newer C7s. When I got my first C7 in October 2013 no explanation other than, "It's normal." Since this was not an issue with my C6 Z51 with the same width tires, wondered why. That is what caused me to do the research and found tire slip angle, more like a racing tire, was the answer. That is why, with the same Ackerman steering geometry. the issue goes away with most all season tires that have "normal" slip angles (see Link in post #15.)
However the tire construction is what gives those high lateral "g" numbers in a turn. Well worth using the workaround of not turning the wheel full lock when below ~45F and making a "K" turn. Only an issue with slow tight turns. Goes away when the tires heat up from driving and all normal road speeds.
I see a number of posts indicating it's "normal," but should it be avoided if possible? (2019 Z06) Is it hard on the car or tires?
BTW, I had 3 Vipers prior to my new Vette, and all 3 had this issue. And, my new Vette blows all of my Vipers away, no contest.
Location: I live my life by 2 rules. 1) Never share everything you know. 2)
Received 2,402 Likes
St. Jude Donor '11-'12-'13, '16-'17-'18
