Code U-0077
I'm surprised you didn't get a check engine light, a misfire code, or a service transaxle (puts the car in nanny mode to protect the car from a faulting engine) The service transaxle may briefly show in the center of your speedo, depending on how you have set up your display.
Loose plug wires Loose connectors to coil packs, MAF, etc. Have you removed the air filter box lately? loose leaking connection at TB allowing more air in.
According to my AllData subscription, which draws directly from GM's official service info, this code is for an error on the chassis expansion data bus. DTC U0077 00
- Control Module Communication Chassis Expansion CAN Bus Off
The chassis expansion bus has the following modules.
Brake control
Power steering
Magnetic suspension
Rear differential
Chassis control
Steering angle
Airbags
Some other possibilities
U0002-HIGH SPEED CAN COMMUNICATION BUS PERFORMANCE
U0077-CONTROL MODULE COMMUNICATION BUS OFF
Both of these are codes for loss of communication from the Body Control Module(BCM) to the Engine Control Module(ECM).
This can by from a fault in the communication data lines, or more commonly, a faulty BCM
Symptoms of a U0077 diagnostic trouble code may include:
- Blown fuse (if applicable)
- Engine surge
- Reduction in engine performance, especially at low RPM levels
- The light may stay on or light intermittently as the DPF regenerates. The engine will be sluggish on acceleration.
Possible Causes :
- An air leak forward of the DPF will change the sensor readings resulting in the code
- Rusty exhaust systems, cracked exhaust manifolds or damaged or missing gaskets or donuts will cause air leaks.
- Dirty air cleaner element Damaged DPF
- Engine surge
Possible Causes :
I also checked all plug and coil wires even the side thats impossible to get to!
Thanks to all for their input.
Al
The engine should smooth out after a warmup. Everything is connected to everything else, and the LT engines use the Crank Position Sensor to detect and post misfires. Depending on what is causing a misfire (any rough idle or lack of power, unless the brakes are actuated should be SOME sort of misfire), it may or may not throw a misfire code per se. Gas engines haven't really changed that much since Nick A. Otto came up with the 4 stroke gas engine. They need fuel, air, and an ignition source. Short change any of these and you will start misfiring.
Your code may be a loose connection somewhere, probably in the engine bay that is giving that code, which is a pretty unusual code to say the least. Troubleshooting these cars is like a dentist going through your rectum to clean your teeth, so a little patience and small fingers may be needed to solve this one. By all means be kind to the patient.
That being said, keep looking and finding. My guess is you ain't dun yet. Good start, you solved one issue.
If you have PDR on your C7 take it out and record a street session. You can use the Cosworth Toolbox to compare runs. I think you can set it to compare 0-60 runs, etc.
