Best way to install CB antenna in C7
#41
Location: I live my life by 2 rules. 1) Never share everything you know. 2)
Received 2,402 Likes
St. Jude Donor '11-'12-'13, '16-'17-'18
#42
chevyorange (05-07-2020)
#43
Moderator/Tech Contributor
Location: Jacksonville Florida BWO Dayton, Cincinnati, Bloomsbury NJ, Cincinnati
Received 3,821 Likes
2015 C7 of the Year Finalist
https://www.corvetteforum.com/forums...post1589862556
So all of the "purists" are satisfied with no CB or antenna showing.
Elmer
#44
Received 2,372 Likes
#45
As I said, I have a HAM in my car and the antenna looks like this:
Elmer
Elmer
#46
Mdonnell (10-30-2018)
#49
#50
The 70's called, they want their antenna's back!!!!!
#51
Exception ID 10T
What are your thoughts on the hand held CB radios like this one? I was looking for something more portable to use from time to time rather than mounting a large antenna to my car.
https://midlandusa.com/product/75-822cb-radio/
And for those who did not realize it, CB radio was available as a factory option in a Corvette in 1978 through 1985 model years.
https://www.corvettemuseum.org/learn...orvette-specs/
#53
#54
Received 2,051 Likes
St. Jude Donor '13
Otherwise, you probably have to drill a hole in the tub like Ken says. I keep finding people who say there's a way to do this without drilling any holes or running the wire over the weatherstrip, but when I ask for details I get silence. If you know how to do it without drilling, please post!
On our 2017 2LT coupe, the appropriate place to drill the hole at the rear of the tub is covered by a big speaker/amplifier. Nobody I know could figure out how to drill the hole without temporarily removing that box, which is a PITA.
Anything we do on a C7 seems to take about twice as long as on a C6.
#55
If you are lucky enough to have a 2014 coupe, there is supposed to be a pressure relief door at the rear of the trunk and you can feed the antenna wire out through that and then through the existing opening above the license plate like Ken says.
Mdonnell (11-01-2018)
#58
St. Jude Donor '13
Several years ago we did a comparison test between CB, family radio, and some kind of industrial grade walkie talkie.
The CBs were those all in one cobra units with a typical license plate mount antenna.
One car was my C6 coupe, the other was a C6 vert with the top up.
I sat in our driveway with the engine running, the other guy slowly drove away as we talked back and forth on the different radios.
In short, the CB gave us twice the range of the good walkie talkie and 3 times the range of the FRS. I think it’s the antenna that makes the difference, a handheld CB with rubber duckie didn’t do any better than the walkie talkie.
The following 2 users liked this post by Gearhead Jim:
chevyorange (05-07-2020),
#59
Mdonnell (11-02-2018)
#60
