Splash guard install??
Oct 28, 2018 | 11:59 AM
Oct 28, 2018 | 12:02 PM
From: I live my life by 2 rules. 1) Never share everything you know. 2)
St. Jude Donor '11-'12-'13, '16-'17-'18
Quote:
Originally Posted by
aliix
when installing the splash guards should the front tabs be exposed under the body or sandwiched in?
I removed both front and didn’t make note. As for the rear ones they appear to be sandwiched. Any advice would help.
Lower tab in question.
Gm factory splash guard installed by me. Unsure of tab. Is this correct?
Yup, that's correct
Oct 28, 2018 | 12:15 PM
KenHorse
Yup, that's correct
thanks...
Oct 28, 2018 | 12:36 PM
Oct 28, 2018 | 12:52 PM
Out of curiosity, what year is your GS?
Oct 28, 2018 | 12:58 PM
Oct 28, 2018 | 01:06 PM
Oct 28, 2018 | 01:09 PM
off topic but what kind of floor is that? sharp!
Oct 28, 2018 | 01:13 PM
Ok. There's a lot of OP in your paint - I was hopeful the new paint shop improved the quality. Apparently not
Oct 28, 2018 | 01:14 PM
aliix
New splash shield!
Made in China (no fastner).
For the rear, instructions make no mention of inner fastener needing to be transferred over.
There should be no fastener on that bottom tab....
Oct 28, 2018 | 01:17 PM
tstad9i1
it’s an epoxy (with smoked color chips). From premier garage flooring.
Oct 28, 2018 | 01:20 PM
KenHorse
without the fastner on the tab the screw Has no hold.
Reason: Typo
Oct 28, 2018 | 01:31 PM
aliix
That's the bottom tab, correct? Unless something changed on the 2019 MY, the tab mounts under an existing bolt
Oct 28, 2018 | 01:37 PM
I’m not sure, the front splash shields did not have fastners on the tabs and mounted below.
for the rear it appears there are fastners attached to the tabs and they are sandwiched in. Checking the other side now.
So i had to transfer the fastner over to the splash shield being installed.
Oct 28, 2018 | 01:45 PM
Oct 28, 2018 | 02:24 PM
I transfered the tab to the splash guards also. Works fine..
Oct 28, 2018 | 02:40 PM
dyoung
Did you only have to transfer the faster for the rears?
Oct 28, 2018 | 04:47 PM
aliix
Yes,,only the rears. The front don't have a metal tab. The plastic piece on the bottom goes on the outside on the front.
Oct 30, 2018 | 06:43 PM
Speaking of splash guards, how hard is it to install front splash guards on a Grand Sport? Do you need any special tools?
Oct 30, 2018 | 07:25 PM
robertlevine
Same installation as above, takes about 10 minutes.
