Convertible trunk devider
Old Oct 30, 2018 | 09:15 AM
n_brio's Avatar
n_brio
Default Convertible trunk devider
Does anyone have part number for the convertible trunk devider ?
Old Oct 31, 2018 | 01:17 AM
owc6's Avatar
owc6
The C6 part # is easy to find, but the C7 is not. I can see why you are asking.
Just curious, but what happened to yours?
Old Oct 31, 2018 | 01:26 AM
owc6's Avatar
owc6
I just pulled mine out, and there are no identifying marks on it whatsoever.
I was hoping there was a label or something with a part #.
Old Oct 31, 2018 | 09:54 AM
n_brio's Avatar
n_brio
there was no devider in my car when i brougt it and the sensor was jumpered
Old Oct 31, 2018 | 02:52 PM
Rebel Yell's Avatar
Rebel Yell
Well dang, that ain't right.
Check with some of our forum vendors, CULTRAG, GM Parts Direct, etc. Give them a call, they are all very helpful.
Old Oct 31, 2018 | 03:14 PM
owc6's Avatar
owc6
Just to let you know, the C6 version is $175. I would guess the C7 version will be right in that ballpark.
Old Nov 1, 2018 | 01:19 PM
Rebel Yell's Avatar
Rebel Yell
And I would bet the north 40 that the C6 version will fit the C7. What do ya think Lisa?
Old Nov 1, 2018 | 01:34 PM
owc6's Avatar
owc6
From what I understand, the switch mechanism that tells the car that the Partition is secure is different; the C6 uses a press switch on the back of the grommet, and the C7 uses a magnet. IDK if the distance between grommets is the same, either.
I can measure and check for sure later this afternoon/evening, but unless this C6 partition (that I found on GMPartsdirect) also has a magnet, it wouldn't work even if it fit. Unless n_brio keeps the jumper in place.
Old Nov 1, 2018 | 01:45 PM
GM'er's Avatar
GM'er
2017 C7 of the Year Finalist
Here you go: 23491044
EDIT: If you don't have them, it looks like you will also need the two front retainers that attach it: 11609969
To Convertible trunk devider
