No remote detected?
Old Sep 22, 2019 | 11:58 PM
owc6's Avatar
owc6
Originally Posted by kengray
I have the same situation in my 2017 Z06. The doors wouldn’t unlock. The hatch would unlock by pressing the button underneath, but not with the key fob. I opened the driver’s door with the pull tab in the trunk. I inserted the key fob in the steering column slot and was able to start the car. The driver door wouldn’t open. I had to use the release latch on the floor to open the door. I replaced the batteries in both key fobs and the car still shows “ no remote key was detected “. I replaced the car battery 18 months ago. When the engine is running the digital display shows 14.7-14.8 volts for the battery.
I know this problem has many threads, and the answers are to replace the fob batteries as the solution. But that didn’t work in this case. Any other thoughts or possible solutions ? The car is under warranty, but I only want to take it to the dealership if
I have to.
If was me, I would just replace the car battery. I've been in this dance more times than I can count with the C6/C7.
It's a well-known fact that the cars start displaying wonky behavior when the car batteries get even slightly sub-par.
Old Sep 23, 2019 | 06:26 AM
JerryU's Avatar
JerryU
E-Ray, 3LZ, ZER, LIFT
I have the same situation in my 2017 Z06..... I replaced the car battery 18 months ago. When the engine is running the digital display shows 14.7-14.8 volts for the battery.
Sounds very strange- you replaced the car battery when it was less than a year old??
This was my experience re FOB batteries:
Changed my main FOB battery in my 2014 C7 after ~18 months as a “precaution.” After ~1 year that FOB was not opening the door unless I pushed the FOB open button then it would not start the car without being put in the steering wheel slot. Tried the FOB that was never used and just under 3 years old. It also needed to have the open button pushed to open the door.
Checked both batteries using a battery checker I have had for years that puts a "current draw" on the battery depending on voltage and size. Much better than measuring OCV. Both read just barely in the green OK area. Bought new batteries locally and they read strongly in the green area. They worked fine.
Bottom Line: will change my Grand Sport FOB battery at 2 years with a fresh quality replacements, not the cheap ones I bought from Amazon!
PS: If your car amp meter is always showing 14.7/8 volts that could be another problem. You're not putting on enough miles OR you're only driving short distances. Could be the car battery is in a very poor state of charge. For example, if most drives are short you're NOT replacing the amps needed to start the car! Also as the car sits the battery will decrease in charge. Easy check. Put on a battery charger, bring the battery to full charge and see if the problem goes away! Perhaps why you changed the battery in less than a year! A new battery won't help as lead acid batteries deteriorate if they are not kept charged. Although a different type of battery it would be like taking a cell phone with a dead battery, putting in on a charger for 10 minutes where it read a high charging voltage and taking it off after 10 minutes and saying, "MUST be charged!" No way! Lead acid batteries are even worse as once the charge is very low they deteriorate and do that a few times and they can't recover (unlike cell phone batteries that can be fully discharged without deterioration.) Sure your car's alternator shows high voltage BUT the battery is not getting fully charged. you should see the voltage drop to ~ 13 volts indicating a fully charged battery. That might take a 100 mile drive! One check is after the car is parked for 12+ hours (removing the battery surface charge) check the battery voltage with a meter. That will define the state of charge. The table on the left below provides that estimate. I check from under the hood, no need to access the battery. Pull back the rubber boot on the Alternator wire terminal and put the positive meter lead on it and the negative on a bolt head on the chassis for a ground! If you have a "garage queen" you should do what I do with my street rod and have a maintanence charger connected 24/7!
Old Sep 23, 2019 | 01:52 PM
Bavaria's Avatar
Bavaria
Since I'm the only one driving the car I see no reason to replace the batteries in both fobs, as they need replacement at about the same time interval. After over 4 1/2 years of ownership, my 2nd fob has never been used and probably never will be.
Old Sep 23, 2019 | 02:21 PM
JerryU's Avatar
JerryU
Do as you wish, but I found my 2nd FOB that was in the draw for ~3 years with the OEM battery was also weak!
Old Sep 23, 2019 | 04:08 PM
Bavaria's Avatar
Bavaria
I rest my case - I only change the battery in the fob I use. The battery in the 2nd fob was dead and got pitched over two years ago.
Old Sep 23, 2019 | 04:16 PM
papillion's Avatar
papillion
Default Just the Facts
Battery search suggests a CR2032 should have a storage life of 6-8 years. So a #2 fob never used should be the same. I bought a blister pack at Wal Mart the other day. Four Duracell batteries for $9. Package said best used by 2018. But I was in the DIY mood and changed both fobs. I mean why not? It is chump change and 5 minutes. You'd rather prove some arcane point? Hey go for it eh?
Old Sep 23, 2019 | 05:35 PM
DugT's Avatar
DugT
This has been explained well many times above but I will give it a shot anyway. The battery in a #2 fob is always being used whether the fob is used or not because the receiver in it is always on and always using energy from the battery, day and night until the battery dies. If the fob has a good battery in it, the fob is on whether it is a million miles for the car in a dark closet or in your hand next to the car. If you keep the #2 fob in a closet for two years and then try to use it, do you have to turn it on first? No you don't because it has been on for as long as the battery has been in the fob. The concept is very simple and understood by most people here. It is not the least bit arkane.
Cell phones are similar. If you don't use your cell phone the battery will loose its charge in a few days because the receiver is always on, the same as your fob. If the cell phone battery is being stored outside the phone, the charge will last a year or two.
Old Sep 23, 2019 | 05:57 PM
mschuyler's Avatar
mschuyler
So you "refuse to replace" the second battery "because you never use it." . Eventually, the first battery will run out. You'll reach for the second Fob so you can drive, and Uh oh! That's dead, too. Now you're stuck.
I have a CTS (same tech) and both batteries went out within a few days of each other--at 4-1/2 years. Fortunately, I had learned how to replace one a few days before so it was a slam dunk and took less than a minute.
Old Sep 24, 2019 | 02:30 AM
Bavaria's Avatar
Bavaria
...and when the 1st runs out the 2nd probably has also. The car warns me when the fob needs replacement, and it gets done. I don't follow your logic.
Old Sep 24, 2019 | 08:01 PM
eboggs_jkvl's Avatar
eboggs_jkvl
Moderator emeritus
2015 C7 of the Year Finalist
When the battery in the FOB craps out, you put the FOB in the slot, start the car and drive to the store and buy a new FOB battery, you are not stuck. Inconvenienced, maybe, buy not stuck.
Elmer
Old Sep 24, 2019 | 08:08 PM
owc6's Avatar
owc6
Now might be a good time to remind everyone to check and make sure your physical key actually works in the trunk keyhole.
If your fob battery dies, and the key does not work, THEN you truly would be stuck!
