HELP-Battery so low on power can't open doors & emergency key will not pop rear hatch
#41
I'm going to be checking to be sure my key opens my hatch!
#42
E-Ray, 3LZ, ZER, LIFT
Received 9,625 Likes
ant812 (11-26-2018)
#43
This thread is a good reminder for us to check that our manual keys are working. OP - I hope you're able to follow JerryU's instructions to charge the battery.
#44
This thread conversation reminds me of a tragic event where a man was found dead in his C7 because he lost all electrical power and didn’t know how to use the emergency exit “handles.” As soon as I read that, I went out and demonstrated it to my wife...just in case. Now whenever I take someone for a ride, I make sure I point both of them out. I have also made sure my key will open the hatch and the back cable will open the driver’s door.
#45
Location: Louisville Ky NCM Lifetime Member 429 (Member Since 1993)
St. Jude Donor '12-'13, '16
i need a new battery get the trickle charger on it, and get the rear hatch mechanism opened with the key fixed.
Thanks for everyone's assistance.
The following 3 users liked this post by RACE U:
#47
I thought there was a problem when you posted that you turned the key a full 180 degrees. It only takes a quarter turn.
#49
Optional? I thought it was a standard item. With a dead battery it is the only way to get in.
#51
A lot of people on this thread need to pull out their manual and read a little. Jeeeeeeeeeesus.
F4Gary (11-26-2018)
#52
Great heads up, the car was 5 years old on 13 Nov and has 50k on the clock and I have never tried the key. Mine works and if the battery is up you will set off the alarm.
Finding new roads!
Finding new roads!
#53
Location: I live my life by 2 rules. 1) Never share everything you know. 2)
Received 2,402 Likes
St. Jude Donor '11-'12-'13, '16-'17-'18
"I'm screwed mine does not have the rear key release. I'm thinking of taking it to the dealershi+ and have them install it. I believe it is a safety item."
You really are screwed, that "rear key release" was an optional item on the build and cannot be installed after the fact!
It is FALSE that the key release in the rear is an option - it is STANDARD on ALL C7's...period
#55
And this key and function is not an option. It is a standard feature designed to allow the driver open the drivers door an access the hood release when the battery has no power.
#56
dsword (01-27-2019)
#57
#58
It is broken. Should have to turn it clockwise 30 to 40%, get some resistence. then the back hatch should open.
#59
Moderator
Difficult? Just reach down between your seat and the door and pull the manual door release. If you cannot manage to remember that, take the top off. 3 latches, push it off.
#60
