No climate control
Old Nov 29, 2018 | 09:24 AM
19 g.s C7's Avatar
19 g.s C7
4th Gear
Default No climate control
I’ve had my 19 gs for about 2 months now I have about 1100 miles on her. I came across a new issue of I have no tempature control. Always on hot. No air conditioning. Unable to switch out of sync mode and auto temp doesn’t work 🥵
Old Nov 29, 2018 | 09:33 AM
cowboy casey's Avatar
cowboy casey
mine did something like that when I first got it.. Try changing from auto to manual over and over about 10 times.. mine started working normally...
Mine was stuck on non sync mode and was fogging up the passenger side...
Old Nov 29, 2018 | 10:57 AM
Grand Slam's Avatar
Grand Slam
Try disconnecting the battery for about 5 minutes and connecting again. That should cause car systems to reset.
Old Nov 30, 2018 | 09:01 AM
19 g.s C7's Avatar
19 g.s C7
4th Gear
Default Didn’t work
So I went home yesterday after work. Took the car to work so it was at normal temps and I tried your advice. I must od switched it from ac to sync to manual every temp possible and nothing. Stuck on hot. Air conditioner pulley not spinning or fan. I was wondering if it made sense to try and disconnect the battery before bringing it to the dealer
Old Nov 30, 2018 | 09:13 AM
cowboy casey
hmmmm, the battery may work but something major is happening if the AC will not come on at all... I would not mess with it and just take it to a service adviser, they can connect to it and tell what is happening in 10 minutes...
I have a great relationship with my service adviser and service manager, any time I have an issue i can call and get a same day appointment if needed...
Old Nov 30, 2018 | 02:03 PM
kenownr's Avatar
kenownr
I hope I'm not asking a dumb question (no offence intended at all), but did you press the center button on the temp control ****? It turns the system on/off.
To No climate control
