Blew Coolant Line
I know one that gets on this Forum if someone brings him an aftermarket parts problem he hasn't experienced before.
v0v the fan is pretty much useless (any of them) for track sessions.
The fan only really matters when you come in off track and you're sitting in impound or in your paddock spot.
eta: been through two water pumps and the overflow reservoir hose assembly failed at nationals as the alternator pulley ripped a hole in it.
Read and enjoy the forum and your new C7, tuck some of these problems away in the back of you head, it saved me when I read about this exact event about 2 months before it happened to me...
2015 & 2016 MY for the Torque Converter.
Relax and drive your car!
Elmer
Possibly the controller is in the wiring associated with fan swap but I would be surprised if it was. Or possibly the factory wiring is at fault.
I would think if you can get a shop manual and determine where the temperature monitor/fan switch and wiring is you would be able to solve this problem for a lot cheaper.
I plan on my fan swap on Tuesday. I'll try to remember to take pictures to show the shroud swap on the 2014s.
Elmer
Way to advanced for this forum.
Good plan! I have the manuals but I don't plan on purchasing a scanner. I let the dealer do the scanning with his tools. The problem is hard to see as it will come clear with the stop and restart of the engine. With the engine temp spiking, it is difficult if not impossible to get the car to the dealer in "trouble" mode. It is rare to be able to get to the dealer with the trouble event ocurring and not lock up your engine. I know that I have an issue, I can't get it repaired unless the dealer sees and confirms that there is an issue, so I have 3 choices:
1) Do nothing and live with the condition until it is so bad the dealer can replicate it at the dealership and get it fixed under warranty
2) Have the dealer replace the fan/shroud/controller for $700 - $800 out of my pocket.
3) Buy the F/S/C and replace it in my garage and save the labor charge.
I picked 3
Elmer
I picked 3
Elmer
it isn't the norm for techs to diagnose correctly and track down multiple issues, so you definitely have a good one, OP.
