This is not your normal tire question
Most tire posts are about what brand of tire should be purchased. This post asks, should I replace my existing tires.
We plan to take a long roadtrip this summer traveling around 7500+ miles. I currently have 17,344 on the original tires but will have around 19,500 by time we hit the road. Even though I have plenty of tread now I am somewhat hesitant to take such a long roadtrip on lower tread Summer Only Tires especially given that I am sure we will hit plenty of heavy rain storms while driving on the northern U.S. highways.
So this is my dilemma, I estimate I will have a total of 27,000 on the tires before we arrive back home. By then especially the return leg of the trip I could be below 4mm (62% worn) or maybe even 3mm (78% worn) of tread left. Not the best for rain soaked roads.
If you were in my shoes would you replace the tires with new Pilot Sport All Season ZP Tires BEFORE hitting the road rather then squeezing every mile out of the original OEM tires?
I would put a new set of tires on the car and call it a day. No need to concern yourself with tire safety on a vacation. Just one less thing to worry about.
Have a great time!
Have a great time!
You're not going to burn off as much tread on 7,500 highway miles as you would 7,500 miles stop and go. Check them before you leave and if they're still good to go swap them when you get back,
The following 3 users liked this post by FLEXjs:
I would replace them after the trip, but you really seem concerned with driving in the rain with worn tires so I guess for piece of mind change them prior to leaving.
The following 2 users liked this post by dvilin:
jimmie jam (12-28-2018),
Maxie2U (12-27-2018)
Location: I live my life by 2 rules. 1) Never share everything you know. 2)
Received 2,402 Likes
St. Jude Donor '11-'12-'13, '16-'17-'18
Seems a slam dunk to me
Blow a tire out in the middle of nowhere and have to wait (for possibly days) for replacement(s).
Change 'em BEFORE you go (greater chance of a worn tire going flat or blowing out than a newer one)
Received 2,639 Likes
Received 2,093 Likes
Since "worn out tires" are already causing concern for @Maxie2U, I'd recommend replacing them before the trip for peace of mind. Driving 7500 miles and worrying about every little shower or rain storm doesn't sound fun. Neither does hydroplaning on worn out tires. The wear on a new set will be negligible, and full tread depth in an unexpected downpour would give some reassuring grip in the wet.
A third option might be, depending on your vacation schedule, having Tire Rack ship new tires to a place where you could have them mounted along the way. You could have them shipped ahead of time and it shouldn't take much time to get you up and running.
Forget Tire Rack!
Discount Tire or DiscountTireDirect.com will send your tires to any one of their stores nation wide.
And your lifetime balancing is good anywhere you go. If you do road hazard, DTC can get tire next day delivery to the store.
You decide... Tire Rack? Why?
Discount Tire is the best tire company to deal with!
Try the AS3+.
Try the AS3+.
The following 2 users liked this post by MikeERWNC:
Maxie2U (12-28-2018),
Rebel Yell (12-28-2018)
You can always tell a Jarhead, You just can't tell them much.
Moderator
4/32" (0.125" or ~3.2mm) is considered the minimum tread depth for maintaining wet traction. By your estimates, you'll be at that or better. So, if the thought really bothers you, replace them before you go. I probably would wait until I got back.
Received 19,414 Likes
'20-'21-'22-'23-'24
Why worry about it while trying to enjoy your vacation - go ahead and get them replaced before you leave and have a good time on the trip.
How about putting on a set of fresh tires now, but keeping the old ones to sell to someone else to recoup some of the cost?
Received 2,057 Likes
St. Jude Donor '13
Maxie-
We have the A/S ZP on a second set of wheels/sensors, and swap out each Spring/Fall with the PSS. Since I'm an occasional autocrosser and track rat, that works well for me.
We have used the A/S as our touring tire because it's usually cold weather (below 40'F, or snow) somewhere along our trips, they have worked fine for temps up to 90'.
If you think you might be using your car like ours, then the cost of the extra wheels/sensors is worthwhile and you can install the A/S before your trip.
If not, then I'd just put on the A/S before and be done with it. As others have mentioned, the peace of mind and actual safety of the new tires are worth something.
Assuming you couldn't sell or swap your used tires for something, you will be losing something around $250 worth of life from the PSS. With hotels/food/gas/misc/wear, we spend almost that much per day on a trip.
