Corsa Extreme
Old Dec 28, 2018 | 03:58 PM
rvan's Avatar
rvan
Default Corsa Extreme
Have a Borla x-pipe on my 2015 Z51, with NPP Looking at Corsa Extreme exhaust. I know Corsa doesn't have NPP, however it appears Corsa makes an axle back and valve back option. What are the differences as far as sound, fitment (w/ Borla X-pipe), and ease of install? Any recommendations?
Old Dec 28, 2018 | 04:15 PM
CCA Corvette Parts's Avatar
CCA Corvette Parts
Premium Supporting Vendor
St. Jude Donor '07-'08,-'13-'14, '16-'17
The only Xtreme option for the way your car is equipped are the following
14762/BLK Valve Back
or
14763/BLK Valve Back
I have some 14762 and 14762BLK instock if you are interested
Regards
Chip
__________________
..................Click for
Old Dec 28, 2018 | 04:25 PM
rvan's Avatar
rvan
Default Corsa
I have seen the 14762, what is the 14763?
Old Dec 28, 2018 | 04:26 PM
CCA Corvette Parts
Polygon Tip
Regards
Chip
Old Dec 29, 2018 | 12:30 PM
MerakiAutoworks's Avatar
MerakiAutoworks
Supporting Vendor
If you want to retain the AFM function so you don't get a check engine light you need #14762/3 and cut/weld the AFM from your stock exhaust onto the Corsa.
For a straight install you can do 14766 but only if you plan on getting a tune or don't mind having a CEL.
Contact us for pricing or questions!
-Josh
Old Dec 29, 2018 | 01:54 PM
rvan's Avatar
rvan
I thought you had to cut the exhaust, but then clamp it together with the supplied clamps. I also have the range for the AFM issue.
Old Dec 31, 2018 | 01:45 PM
MerakiAutoworks
Supporting Vendor
^ correct.
-Josh
To Corsa Extreme
