Automatic convertible top
Old Jan 5, 2019 | 01:06 PM
boxster99t's Avatar
boxster99t
Originally Posted by stevenpeter
I am not sure. I bought it with 7000 miles on it. It has dual exhaust, carbon package, 2LT. I will take photos this weekend and post. And sure, if anyone can tell me where to find if a module was installed. THANK YOU
In addition to trying the programming instructions for SmartTop,before you pull the waterfall out, you might look for a USB cable coming from behind the waterfall (it comes with the SmartTop and allows one to connect a windows or Mac laptop in order to do firmware updates). I have the USB cable on mine tucked loosely behind the waterfall, and you'd only see it if you move the driver's seat up and look.
Old Jan 5, 2019 | 02:04 PM
stevenpeter's Avatar
stevenpeter
4th Gear
WOW, thank you so much for ALL the info and detailed instructions. I am very grateful!!! You guys are great!!!
I DO NOT see a module under the steering column. Everything works but the windows rolling up after putting the top in the UP position.
Maybe I can find a module online or through the manufacturer.
Steven
Old Jan 5, 2019 | 02:06 PM
stevenpeter
4th Gear
I DO NOT need to hold the button down on dash (or keyfob). I just tap the top up or down button on dash and the top does its thing. I can also open the top by tapping 3 times on the door release handle. It is really a great add-on.
I had no idea the car had the smartop module. Found out by mistake when I took my finger off the top button one day and it kept going down.
Old Jan 5, 2019 | 02:07 PM
owc6's Avatar
owc6
When I bought mine in Sept, There was no window module available for 2018 or 2019.
Your best bet would be to contact the manufacturer and see if they have come out with one, yet.
eta: just checked, and it still is not available.
Old Jan 5, 2019 | 04:12 PM
GARYFINN's Avatar
GARYFINN
From: S/W ,Fla-Ohio State Football isn't a matter of life or death,Its Much More serious than that
Originally Posted by eboggs_jkvl
No where in my reply did I indicate that it was free. I personally think it is worth the money.
Elmer
Nowhere in my reply did I state it was for free !! I just think that almost $500 is a little pricey.
