Central/SE Ohio tire service recommendations
Navigator
All,
Just received delivery of my new 19 Grand Sport. As the winter progresses I’m looking at the possibility of buying a set of A/S tires to put on when the weather gets better. Looking for recommendations from those of you in the Central/SE Ohio area where you would recommend having the tires swapped. I do not want to take them to a local tire shop and risk damaging the wheels. Thanks in advance for all assistance.
I have a 16 Ray w/ Z51 wheels (19 & 20"). About a month ago, I swapped the MPSS summer only tires for a set of MPS A/S 3+ from Tire Rack. I love them, no low speed chatter, secure grip in low temps, great wet traction. Also mine are run flats with a very comfortable ride.
Coughlin (Rick Conti) in Pataskala near Columbus is a big national Corvette dealer. Their dedicated Corvette mechanic does all work on any Corvette, including tires. They have mounted 8 tires for me with no problems.
Navigator
Thanks for taking the time to reply. Will definitely check them out.
