What year to avoid purchasing?
Old Jan 19, 2019 | 09:34 PM
Kingman99's Avatar
Kingman99
Default What year to avoid purchasing?
Hi
Need some advise which year C7 vert should l avoid and the best year to buy. I have owned vettes on and off since 1968
all coupes except my last c6 vert. Must have auto top, nav and be able to have cameras in front and back. I know l will need a new radio.
thanks
Old Jan 19, 2019 | 10:58 PM
B-17/B-25 CC's Avatar
B-17/B-25 CC
I wouldn't say there is any particular year to avoid, it's more like what options to avoid. The '14s had the six speed auto trans that seem to be bulletproof. The '15s and up have the A8 which many have had (and continue to have ) problems with-myself included. To get the front cameras, you will need the 2LT or 3LT level interior. The 3LT can have problems with the leather dashboard coming up around the defroster vent (mine did) and other problems. Extended warranties won't pay for trim problems.
There are many posts about those problems, even a "sticky" about the A8s.
Old Jan 19, 2019 | 11:05 PM
Kingman99's Avatar
Kingman99
Thanks for your reply l believe my C6 had the six speed auto and l had no problems. I will go through the posts.
Alan
Old Jan 20, 2019 | 12:27 AM
Avanti's Avatar
Avanti
B-17 is probably correct. It is hard to give a truly meaningful answer, because most don't have problems... that said, I never buy a new series Vette before the fifth year of production. Just saying.
Old Jan 20, 2019 | 01:05 AM
mdolandese's Avatar
mdolandese
They didn't have front cameras until the 2016 models
Old Jan 20, 2019 | 01:15 AM
If front cameras are a must have, you'll need to go with a '16 or newer car.
Old Jan 20, 2019 | 06:23 AM
Ih2lose's Avatar
Ih2lose
A Valid question , I would suggest the newest car you can get, these cars are awesome. there is also a cool option called a PDR (performance Date Recorder ) I am not sure when it started ,but you can set it so when you valet your car it records what's happening, it meant for a race track but it real cool option . Good luck on your purchase your in for a treat. Not sure if your local to Kerbecks in Atlantic city but if you click on there deals of the day they have cars on sale less then some of the used cars I see advertized.
Old Jan 20, 2019 | 08:43 AM
rckt's Avatar
rckt
I also am looking for a used C7, but have seen the dealers discounting new ones 8k-10k. Should I wait for the C8 for the C7 prices to drop more? I've never seen new corvettes drop more than they are now. I may have to pull the trigger soon.
Old Jan 20, 2019 | 09:21 AM
THE BUD MAN's Avatar
THE BUD MAN
St. Jude Donor '12
I would talk to Mark at MacMulkin...…. I just purchased a GS, sticker $75k for 65k..... deals are out there. I'm sure that Mike at Criswell has equally good deals..... it's just a matter of finding the right car. I wanted a 2019, MT (last of the FE's!)….. I'll sit back and watch the C8 for at least a year and see how things go.
Old Jan 20, 2019 | 09:36 AM
rckt's Avatar
rckt
How does it work getting a car registered and shipped to FL? When you buy out of state, doesn't FL charge impact fees?
Old Jan 20, 2019 | 09:42 AM
sTz's Avatar
sTz
The whole C7 run has been “generally” reliable as mentioned. I’ll add that if you’re looking for a Z06, then ‘17+ will have better cooling if you plan on tracking. Although, I have a ‘16 w/no issues...
Old Jan 20, 2019 | 09:52 AM
Kingman99's Avatar
Kingman99
Hi
I am not looking to pick up a new vette because it’s going to be a third car for tooling around and occasional road trips.
I thought Dennis from Wisconsin was our electronics genius who sells radio / Nav packages with front and rear cameras.
But let’s not get ahead of myself, a little more reasearch is needed
thanks
That’s a great question, by the way the West Palm area is loaded with vettes! What got me started was driving around West Palm
Old Jan 20, 2019 | 10:22 AM
JK 23112's Avatar
JK 23112
I have heard a few folks complain about the A8 in the 2015+ Corvettes. As stated above, the 2014 models had a six-speed automatic and you don't hear anything bad about them. I am a manual transmission kind of guy and my 2017 has the 7-speed. No issues with it at all. I can't say I would "avoid" any year C7 if you can find the car with the color & options you want - and the price is right. There are plenty of them out there for sure.
If you want to shift gears for yourself, the 2019 model will likely be your last chance to do so. The C8 will be an automatic only car.
Old Jan 20, 2019 | 10:50 AM
rckt's Avatar
rckt
Where in West Palm? Roger Dean does not discount. Autonation discounts a little. Seems like Kerbeck or Bomnin in Miami.
Old Jan 20, 2019 | 11:40 AM
bjones7131's Avatar
bjones7131
Avoid the 15 for sure, they seem to have more TC issues but not limited just to the 15.. Also avoid the base stingray A8 that has the dreaded WARBLE problem differential. GM bought my 16 base stingray back for this reason, long post on it I authored, read through it. Still see post with newer vettes have this same problem so GM still hasn't solved this problem. Base stingray A8 has different diff. that GS, Z51, and Z06.. Good luck
Old Jan 20, 2019 | 11:48 AM
Foosh's Avatar
Foosh
While I believe there is no C7 MY one should necessarily avoid, it is true that 15 C7s equipped with the then new A8 probably had more reported problems than any other year. It's also safe to say the ancient guidance to avoid first year models" does not apply to the C7. I could be wrong, but if memory serves me correctly, I believe 2014s scored higher in initial quality than many subsequent MYs.
You're not going to get valid data by simply tallying up all the individual experiences here because they are single data points. In my case, I had zero warranty repairs on my 2014, but did have an early 02 sensor issue on my 2018.
Old Jan 20, 2019 | 12:05 PM
rothchilds's Avatar
rothchilds
FWIW I have a 15 with an A8. Replaced a harness in the transmission due to a rough park to reverse when cold. Other than that, not a single hitch.
To What year to avoid purchasing?
Old Jan 20, 2019 | 12:23 PM
Foosh's Avatar
Foosh
Also FWIW, I suspect most problematic A8s have been successfully repaired under warranty by now, and are fine.
Old Jan 20, 2019 | 12:48 PM
Deepdiver's Avatar
Deepdiver
16s and above will give you Apple carplay.
Old Jan 20, 2019 | 01:24 PM
Corvette ED's Avatar
Corvette ED
From: Pottsville, PA. USA Home Of America's Oldest Brewery Yuengling
Look for some big rebates on 2019's this spring. When GM shows the C8 the 19's will get some big rebates to move them!!
