Side mirror failure
Old Jan 30, 2019 | 09:31 PM
Guitarking1's Avatar
Guitarking1
Default Side mirror failure
My right side power mirror stopped wording on my 2018 GS. I haven't tried to adjust it for many months after I originally made the driver adjustments shortly after I bought the car new last year. However, today, after I had coincidentally made a rare visit to the dealer to get my oil changed along with a safety inspection, I decided on the way home that a slight adjustment might be needed to the right side mirror, but no cigar in getting the right switch and toggle to work.
Any one experience a failure with their power mirror?
Old Jan 31, 2019 | 12:37 AM
Haven't seen much on this problem, but your car should be under warranty so a visit to the dealer may be in order. Good luck.
Old Jan 31, 2019 | 01:30 PM
Rebel Yell's Avatar
Rebel Yell
Not trying to be a smartass my friend, but did you make sure the switch was pushed for the right side mirror before you tried the adjust? The reason I ask is I have missed that step before, and thought something was wrong with the mirror.
Old Jan 31, 2019 | 06:27 PM
Guitarking1
Yep.
It looks like this is not a common problem; only for me!
Old Jan 31, 2019 | 07:42 PM
2019GSTX's Avatar
2019GSTX
Lurker
St. Jude Donor '19-'20
Just for grins, try a couple manual folds of your mirror and then see what happens.
I've had issues with my Chev truck (folding mirrors) before and played with the mirror manually. Almost like doing a reset.
Cant say it will work but if its maybe an intermittent wire break in the mirror it might work.
If I was messing with this out of warranty I would start by pulling pins/wires at the switches and swapping left to right and see if the problem transfers. Thats cuz I'm a cheapskate and I like to see how sh*t works.
I have seen the motors fail and the gears strip but that shouldn't be the case with yours as it has been in that position for awhile, basically not adjusted/run thru the up/down/left/right motions.
Good luck brother....
Old Jan 31, 2019 | 07:50 PM
Maxie2U's Avatar
Maxie2U
Originally Posted by Guitarking1
Yep.
Very uncommon problem but an easy item for your dealer to replace.
Old Feb 1, 2019 | 05:04 PM
$$$frumnuttin''s Avatar
$$$frumnuttin'
From: Should this thoughtful, valuable contribution meet with no acknowledgement or 'thanks' this post----
When I encounter a gremlin like that I simply pick up a Strat and play some blues!😀 seriously, warranty is on your side....
To Side mirror failure
