2016 Z51/ #LT-- new to me with only 1200 miles
noticed pulling toward right
4 wheel-alignment done, problem the same
had techs look carefully under car for damage to suspension, frame, body-- states they found none
what else should they look for (in shop tomorrow)--tire problem? steering gear problem?
Get the tires/wheels checked - bent/cracked/out of balance/etc. That should have been step 1 before an alignment. I'm actually surprised that wherever you took it for an alignment didn't do that first.
Does it pull on every road? Some roads are crowned and the wide tires on a Vette will track to the grooves, so if it's not pulling on every road, it's probably the road.
Why not post a picture your alignment sheet with before and after measurements? A brake dragging could cause the car to pull as well as a tire with a low or high pressure or a tire that has a conicity problem.
What roads are you driving on? With a road crowned to the outside the car will pull right if you drive on the right side of the crown or will pull to the left if driven on the left side of the crown. Does your car pull to the right when in the right hand lane and pull to the left when in the left hand lane? If you are getting a pull to the right of the crown then the mechanic may not adjusted the alignment sufficiently enough to compensate for the pull of gravity.
Bill
Had this problem with our C6. The alignment guy said it was probably the tires. When the front tires wore out (prematurely) and I replaced them, the problem went away. So it was the tires!
I always assumed that my C7 pulls to the right because it's a Republican. I'm a liberal Democrat, doesn't bother me unless my car gets the right to vote.
going to pick the car up tonight-- thanks for the responses-- tech assured me its 'now driving 100% straight--- (after repeated adjustments), and inspected for tire damage/ wheel damage/ suspension damage/ steering linkage damage/bent frame
Id be interested in seeing the before and after alignment specs.
Its pretty unusual for a new car to pull to one side or the other. Not impossible, but unusual.
