Spring Mountain--left foot braking?
Old Feb 13, 2019 | 12:05 AM
Corvette farmer's Avatar
Corvette farmer
Default Spring Mountain--left foot braking?
Do the instructors at spring mountain use or teach left foot braking on the track? I’ve never tracked a car before and was wondering what they do.
Old Feb 13, 2019 | 01:46 AM
Silver C7's Avatar
Silver C7
Not among techniques taught or discussed during my two day stay.
Old Feb 13, 2019 | 03:36 AM
Iconic's Avatar
Iconic
Miller Time Wisconsin 🍺
2021 C7 of the Year - Modified Finalist
2018 C7 of Year Winner
2017 C7 of Year Finalist
St. Jude Donor '13 thru '22
I been out there twice, 4 days total, and they have never mentioned or tried to teach anything about left foot braking.
Old Feb 13, 2019 | 08:05 AM
Thunder22's Avatar
Thunder22
Nor heal/toe any more either.
Old Feb 13, 2019 | 03:47 PM
eagleye's Avatar
eagleye
When I was there last month, someone in the classroom asked about using both feet while driving on the track and they said what ever you are comfortable doing, continue to do it. They don't recommend it since the manual trans people already need both feet for the gas and the clutch.
Old Feb 13, 2019 | 05:46 PM
jimmbbo's Avatar
jimmbbo
They discussed it in response to a question, but with the ARM system, is not necessary nor is it taught.
Old Feb 14, 2019 | 01:55 AM
chas57006's Avatar
chas57006
Navigator
I normally left foot brake.
At spring mountain I found it easier and faster to use only my right.
It took a couple of laps of really concentrating on keeping my left foot glued to the floorboard.
Old Feb 14, 2019 | 08:49 AM
gliot1's Avatar
gliot1
St. Jude Donor '12-'13
Apparently you are all A8 drivers! Those of us with Millenial Theft Control only use our right for gas brake....we use our left for a clutch!
Old Feb 14, 2019 | 12:38 PM
JMII's Avatar
JMII
good one!
Old Feb 14, 2019 | 12:49 PM
Bill Dearborn's Avatar
Bill Dearborn
Actually left foot braking is a fairly sophisticated driving technique. It is easier with an automatic but it is possible to do it with a manual transmission car. There are plenty of online videos taken from NASCAR cars running on road courses where drivers like Ricky Rudd drove around the course using the right foot for the throttle and the left foot for the brake. Here is a Ricky Rudd video from 1994. Check the footwork beginning at 22 seconds into the video:
You may notice he downshifts at least once without touching the clutch.
Bill
Old Feb 14, 2019 | 06:37 PM
gliot1's Avatar
gliot1
Not anymore....NASCAR cars are clutchless now. They still manually shift but blip the gas to clutch at shiftpoint. Listen to the shifts. When they went to this they had cameras mounted to show their feet. That Tide car is pretty ancient history.
Old Feb 14, 2019 | 06:58 PM
Bill Dearborn
I really haven't paid much attention to what NASCAR does now. However, the video still highlights how sophisticated the process is and how left foot braking can be used in combination with right foot throttle control to improve a car's cornering by shifting weight from front to rear. If a driver uses their right foot to do that they lose valuable time moving the foot back and forth.
Bill
Old Feb 14, 2019 | 07:53 PM
spinkick's Avatar
spinkick
If you watch rally guys they look like they are tap dancing because they right and left foot brake/clutch. Sometimes you gotta be on the brake a little bit to settle the car.
Old Feb 14, 2019 | 08:40 PM
Sebring Bill's Avatar
Sebring Bill
I discussed it with a couple of the instructors when I was there in December. I had been encouraged by the AutoX instructor to learn left foot braking to reduce lap times by about a second on a very tight go cart track we run on in Circleville Ohio.
At Spring Mountain I was told that it was OK to do whichever I was comfortable with, but that they did not teach left foot braking. Later I had the opertunity to discuss track driving with Richie Hearn, and his opinion was that a Corvette would perform best with right foot breaking because the slight additional time would allow the chassis to settle before turning. He said some faster cars such as Indi cars did not need that extra time.
Old Feb 14, 2019 | 08:48 PM
Corvette farmer
Good discussion
Old Feb 15, 2019 | 07:49 AM
gliot1's Avatar
gliot1
I am guessing no one here is as good a competition driver as Ricky Rudd or even Ricky Bobby. Seeing a pro do something is many times very hard for amateurs to aspire to. I watch pro golfers put fades on the ball to go around obstacles, and I try to do it but keep falling short...lol i will say on the road courses I have run or auto cross events, once you get into the high gear you dont need to downshift a lot, normally in only a couple spots, so you could use just left foot. For most folks here on a 1 mile plus road course with many turns will a second make that much difference? Most likely not, being the real gains in times come from running clean/smooth without mistakes and hitting your marks. Hell in many cases a 1 second error in the pits with pros means little. The only time I have had to shift a lot was when I started boiling my brake fluid on my 1996 makimg me use my gearbox for braking to let the fluid cool. I agree with many here in that you should do what is comfortable. I have right foot braked for 45 yrs because of stick shift and I plan on still doing it that way when I go to Spring Mountain next week!!!!
Old Feb 15, 2019 | 08:01 AM
Big Lebowski's Avatar
Big Lebowski
Lol, I was thinking the same thing!
To Spring Mountain--left foot braking?
Old Feb 15, 2019 | 09:24 AM
vdavenp802's Avatar
vdavenp802
If you do this on the street (cars), then you will prematurely wear out you brake pads....but, hey its only money.
Old Feb 15, 2019 | 09:37 AM
Racingswh's Avatar
Racingswh
I am guessing no one here is as good a competition driver as Ricky Rudd or even Ricky Bobby.!
Comical to me when people generalize like this on forums. Not to be boastful but I am pretty sure I can out drive Ricky Bobby!! I do not however think I could run around in my underwear trying to get the attention of Oprah and Tom Cruise as gracefully as he did!!
That footwork by Rudd was pretty special. I had not seen that before. Thanks for posting that Bill!
A few years ago forum member Southern Son posted something that I will never forget. He said there may be those that LFB but he would be surprised if they were quicker. Meaning guys like me, pure amateurs that do 5 to 10 events each season so 15 to 30 days total. I was a LF braker in my car at the time. I used my right foot again and checked my lap times and damn if he wasn't correct. Made no difference. I was slow either way.
I am however a little quicker using my LF for the brakes in a DCT equipped car. In my Wife's C7GS or in my C6Z I would still bring my left foot over to cover the brakes approaching fast sweepers if no downshift is required out of habit but lap times don't lie. For me it does not matter.
Old Feb 15, 2019 | 11:13 AM
JMII's Avatar
JMII
Originally Posted by Sebring Bill
ILater I had the opertunity to discuss track driving with Richie Hearn, and his opinion was that a Corvette would perform best with right foot breaking because the slight additional time would allow the chassis to settle before turning. He said some faster cars such as Indi cars did not need that extra time.
The sooner you get off the gas and onto the brakes the better. You should never be "coasting" on track, unlike street driving you don't lift and wait. So in theory left foot braking would have a small advantage until you learned how to switch between pedals with lighting like reflexes. However nobody doing an HPDE type even needs to shave .02 to get the pole position. Its more important to focus on other things (being smooth, hitting your marks, hand position, eyes up, etc) then trying to eek out fractions of a second in each braking zone.
