Least expensive way to break into my car?
As eboggs keeps telling you, use a jump pack or even a battery tender to provide power to the FOB interface receiver and lock system. Put the positive lead on the battery hot connection on the starter solenoid and the other lead on any chassis ground. Because you are only dealing with very little current to operate the unlock system you can use small clip leads from your jump pack to the 12V positive and ground connections; these smaller gauge wires and clips are easier to maneuver in limited working room.
You might try going in thru the rear side of the of the drivers/passnger door glass and trying to pull on the manual door release. a slim jim may not be long long enough but there should be some other thin flat piece of metal that could be notched to grab the lever, should be able to be done without damaging the weatherstrip just a thought
Moderator/Tech Contributor
Location: Jacksonville Florida BWO Dayton, Cincinnati, Bloomsbury NJ, Cincinnati
Received 3,822 Likes
2015 C7 of the Year Finalist
Sadly I know little about the mechanical side of cars. I assume all of what you said is happening from underneath the car? I jack the car up so I can be under it with access to reach up to access the starter... I have called a mobile mechanic and will read him what you wrote to help him help me get this car open. Thanks!
The following 2 users liked this post by retaf87:
Ih2lose (02-17-2019),
Movie Muscle (02-17-2019)
Thanks for the diagram eboggs! I’ll go over that with the mechanic when he gets here later today.
locksmith just came and tried the manual lock, accessing via windows, etc. then he said. “Beautiful car. Stupid car.” And left.
I really have the perfect/worst situation. My car is backed into my very small garage. So I can't tow it out with the electronic emergency break disabled. So would have to jack the car, but rollers on the back wheels and push it out of the garage and down into the street where I have enough room to rotate the car so it can be pulled backwards onto the tow truck as front on would probably crack my front splitter... so that is an option...
Check with the Fire Dept. There wasn't a car made that we couldn't get into, especially if a child or medication was locked in it. We usually use the Big & Easy.
You can get in through either window by pulling it back a bit with a wedge and grabbing onto the manual release down by the floor with a long V bar.
That's the long bar with a bent "v" at end of it. Tow driver should be able to do it for you. If not? Order the kit from Amazon. Dont break the glass.
#33
don't jack it up yourself,,
get a pro to do it,,if you jack it up in the wrong place -you could crack the body
or worse ,the jack could slip and drop the car on you while your under-neath it,,and kill you
#35
I am here for the outcome
z51vett
Doug
z51vett
Doug
#37
Perhaps a long shot but you could try the GM connect App to unlock your car remotely. I don’t have an onstar account but can still send the signal from my smartphone...maybe the different signal has enough juice.
#38
We are sure the battery is dead and the FOB is good, right OP?
Elmer
#40
I can unlock the car without the FOB theough the App...just say may be a different circuit that still has some life
