Wheel Alignment
Old Feb 17, 2019 | 11:11 AM
throhrer's Avatar
throhrer
4th Gear
Default Wheel Alignment
Has anyone noticed excessive tire wear with the factory alignment settings??
Old Feb 17, 2019 | 11:37 AM
John Ulrich's Avatar
John Ulrich
Yes, but this was at 35,000 miles.
Old Feb 17, 2019 | 12:02 PM
PatternDayTrader's Avatar
PatternDayTrader
Yes.
Old Feb 17, 2019 | 12:23 PM
throhrer's Avatar
throhrer
4th Gear
Not bad for 35K miles. Think I will re-align to try and eliminate that. I don't do any track time, so all the high speed handling isn't necessary.
Thanks,
Tom
Old Feb 17, 2019 | 01:37 PM
PatternDayTrader
Thanks,
Tom
Set it up with zero camber or very close to zero. The tires last longer and the car handles better.
Why these cars come with settings that are pretty close to a track only car, is hard to understand.
Its like setting up a track only car with street settings. Stupid.
Old Feb 17, 2019 | 02:33 PM
TNSQUIRE's Avatar
TNSQUIRE
First thing I do is take it to an alignment shop and have a street alignment done. They come with track alignment from the factory and it will destroy the inside of your front tires.
Old Feb 17, 2019 | 04:11 PM
speedlink's Avatar
speedlink
The factory alignment is all over the place. You should get your car aligned as soon as possible when new. Don't trust the factory settings!
Old Feb 17, 2019 | 09:37 PM
Gearhead Jim's Avatar
Gearhead Jim
St. Jude Donor '13
I don't know if it's because the factory doesn't get the alignments right, or if they change as the car settles when you accumulate some miles.
The GM tolerances on alignment specs are absurdly wide, and still all four new Corvettes we've had over the years had at least one parameter that was outside even the factory range when almost new.
You can get a free alignment during a certain range of miles (something like 500 to 4,000, but don't trust my memory) if you tell the dealer that "it handles funny at high speed, please check the alignment" or some such. Our local dealer doesn't ask too many questions and will use whatever specs I give them, just so long as they are within the factory range for warranty. They do a good job. OTOH, some dealers do a really crummy job, hard to predict.
The C7 is one of the few cars in the world where the rear caster is adjustable, it requires special tools that many dealers don't even know exist, and can't be measured on a normal alignment machine. The service writer will usually tell you they can do it because he doesn't know any better. Do your homework and know what you're talking about with the guys.
Old Feb 18, 2019 | 02:40 PM
SlasherMcGee's Avatar
SlasherMcGee
What model do you have? If it's a GS or Z06, your wheels could be bent leading to faster tire wear..
Old Feb 18, 2019 | 03:57 PM
TXSteveF's Avatar
TXSteveF
I second the rear castor setting comment above. My dealer actually explained it to me so they knew what they were talking about they just didn't get it right the first time. When I got the car back I noticed when I hit a small dip on the toll road going about 75-80mph the car swayed left then right. As I read in a older post it felt like I was in a boat that get hit on the side by a wave. I brought it back and they realigned it and now it's perfect. Make sure you take it to someone that understands that rear castor adjustment or they will screw it up. Somewhere on here I read that there are very few cars that have it so most shops don't understand it.
Old Feb 18, 2019 | 04:31 PM
Foosh's Avatar
Foosh
There is no one factory alignment setting, because they spend very little time aligning the cars precisely after assembly. They are all over the map, and it pays to check shortly after taking delivery.
Also agree on the rear caster setting observations above. We've seen new cars with positive rear caster settings on one side and negative on the other. That can cause real handling problems.
To Wheel Alignment
