Everything reset just fine but when I put it in track mode I cant get the hockey stick screen. Is there a way to change settings in track mode? Battery was almost 5 years old installed a amg what a bitch of a install.
I read something and I cant remember where if you attach a battery charger to the cables you wont lose your settings as power keeps flowing to electronics
My 2014 battery was out for one hour. Only thing I had to do was index my passenger side window not even the driver's side. Many report the same. Always can be different. Doubt the GM (or equivalent) charger will work as if it doesn't "see a battery" it shuts down. Some have used a small 9 volt battery (they sell such devices) but in the C7 no real need.
Great thread, it is a pain in the *** to reset anything back to your "Normal".
How long can you have the battery out of car before you start loosing settings???? 2017 GS
and a good question, can I attach my trickle charger to the cables while the battery is out and
anyone know best place and part number for the battery "pull up" cable/handle to remove...????
The memory settings are stored in ROM and none are lost with the battery out during replacement. The only thing that I know that needs to be reset is the window index function and all is well.
Well, then they use a good stone tablet and chisel them down because I didn't lose any memory settings on my car for my battery change. Only had to index the windows.
Elmer
Wherever it's stored or if they have small battery that keeps that memory, my experience and most others who have posted say only window indexing required.
