Scraped front ground effect, please help...
Old Feb 22, 2019 | 01:27 PM
chromeXskull's Avatar
chromeXskull
Default Scraped front ground effect, please help...
New 2019 Grand sport owner and just now when parking at work I parked to close to the curb and scraped the very middle of the front ground effects. I previously had a camaro and never did this and always gave myself plenty of room so I am not sure what I was thinking or doing right now but I’m so mad and about to freak out. Is there a cheap easy fix for this or am I screwed? Any help would be really appreciated.
Old Feb 22, 2019 | 01:29 PM
KenHorse's Avatar
KenHorse
From: I live my life by 2 rules. 1) Never share everything you know. 2)
St. Jude Donor '11-'12-'13, '16-'17-'18
Try buffing/fine sanding it down. If that's not good enough, it's not that expensive to replace the "poverty" splitter
Old Feb 22, 2019 | 01:40 PM
bankers1's Avatar
bankers1
Film over the entire splitter. Hides everything and just add more as you see those curbs. $ 75 fix vs $ 750. new splitter
Old Feb 22, 2019 | 01:49 PM
duckvett's Avatar
duckvett
2023 C7 of the Year Winner - Unmodified
2018 C6 of Year Winner
OK, I'll be the "bad guy"........... next time, use your front cameras.
Old Feb 22, 2019 | 01:53 PM
Jeff V.'s Avatar
Jeff V.
It's a stage 1 splitter. Plastic rather than carbon fiber. They're like $100. Less if you find someone selling one they're upgrading from.
Old Feb 22, 2019 | 02:01 PM
The poverty splitter cost about $180-200, the lower end of the range depending on if the dealer's parts guy will give you a break. I just bought one for my car and got it for right at $180, tax included.
Otherwise, do what KenHorse suggested.
Old Feb 22, 2019 | 02:03 PM
mountainears's Avatar
mountainears
2017 C7 of Year Finalist
Time for your first mod. Use this as an excuse to upgrade to stage 2 :-)
Old Feb 22, 2019 | 02:05 PM
chromeXskull
I might head over to Lowe’s and try the fine sanding for now before I replace. Would I need some kind of touch up paint too or just a little sanding to smooth it over? Forgive my ignorance but this is all new to me and not the handiest person
Old Feb 22, 2019 | 02:06 PM
RBarnes's Avatar
RBarnes
Ask the Googles for GM Part: 22922352 and you'll get dozens of vendors to choose from. Very inexpensive part as others have said. Easy to remove and replace too.
Good luck!
Old Feb 22, 2019 | 02:15 PM
Obe1 GS's Avatar
Obe1 GS
There's no paint on the stage 1 spoiler; it's the natural color of the plastic
Old Feb 22, 2019 | 02:18 PM
chromeXskull
Ok thanks, can anyone recommend what grit sandpaper I should try? I’m thinking something at least over 200.
Old Feb 22, 2019 | 02:23 PM
L8ter's Avatar
L8ter
First off, calm down and breath.
The first one is always the toughest one. In other words, it may happen again. So don’t get too carried away with the repair at this point.
Use a knife (utility knife) and cut off the high spots, just clean it up. Then a dark gray sharpie to color it in because they are much easier to use than paint, and call it lovely.
Now get used to your new car, and when you’re feeling ambitious you can follow up with a filler and paint or replace the damaged part.
Jmo, and good luck with the repair!
edit:
If you’re not handy I’d recommend staying away from sand paper at this time, it’ll scratch the heck out of everything else that doesn’t need to be touched.
Old Feb 22, 2019 | 02:49 PM
dvilin's Avatar
dvilin
I would replace it, otherwise everytime you look at it you are going to know it was damaged even with the best of your attempts to repair it.
Old Feb 22, 2019 | 02:56 PM
Mayor111's Avatar
Mayor111
Do front cameras come with all Vettes past 2015 or do you need a 2LT to get them? Im asking because the OP said he has a 2019, just curious why front cameras weren't used OR if he didn't have them due to his option level.
Old Feb 22, 2019 | 03:08 PM
speed4tu's Avatar
speed4tu
I wouldn't even worry about that. Just give it time, it will get much worse. I have the stage 2 with a few dings and the bottom ground up pretty good. Doesn't bother me one bit. Once it's destroyed ill put a new one one it.
Old Feb 22, 2019 | 03:12 PM
tcotta411's Avatar
tcotta411
I have an OEM front splitter for sale. New with hardware. Must pick up in Charlotte, NC. Will not ship. Too expensive.
$100. Firm.
PM me!
Old Feb 22, 2019 | 03:38 PM
Jeff V.'s Avatar
Jeff V.
2016 and up with 2LT or better.
To Scraped front ground effect, please help...
Elk's Avatar
Elk
I suggest performing the repair outlined above and then become accustomed to the car. If after six months or so you do not do it again, replace the splitter.
Old Feb 22, 2019 | 04:17 PM
chromeXskull
1LT so no front camera.... going to sand with a couple different higher grits and hope for best. If it still drives me crazy I’ll replace down the road once I’m more used to the car
Old Feb 22, 2019 | 04:22 PM
vader86's Avatar
vader86
Hell I did that on the first day with the car when I pulled into a steak house. Got pissed, drank a lot, didn't worry about it further. Its gonna get scratched.
Now I use these parking cameras every time I pull into any spot.
