Stinger Questions
Old Feb 22, 2019 | 06:59 PM
Slynky's Avatar
Slynky
Default Stinger Questions
So, I'm thinking I'd like a black stinger on the hood. Thing is, my (ex) wife had stripes on her Mini and they didn't take to wax very well. Didn't have the same shine as paint--which might be normal...I don't know--and sometimes just looked sort of spoltchy.
I'd like something that has the same look as the vents in the hood (which I guess is carbon flash... that sparkle).
So, does the OEM stinger resemble the paint on the vents or is it a flat color?
What are your thoughts about just having a stinger painted on versus applique'?
Old Feb 22, 2019 | 07:12 PM
Obe1 GS's Avatar
Obe1 GS
Paint will always look better than a decal. The best look is to have clear coat applied over the entire hood after the stripe is painted on to eliminate the edge/lip transition.
Old Feb 22, 2019 | 07:17 PM
Slynky's Avatar
Slynky
Originally Posted by Obe1 GS
Paint will always look better than a decal. The best look is to have clear coat applied over the entire hood after the stripe is printed on to eliminate the edge/lip transition.
When you say, "printed on", to you mean "painted on" or sticking on something that is printed? I'm guessing you mean painted and if I do that way, it will be clear-coated to yield a smooth coat.
Thanks for your input.
Old Feb 22, 2019 | 07:19 PM
Obe1 GS's Avatar
Obe1 GS
Typo, I meant painted on (just corrected in my post above).
Old Feb 22, 2019 | 07:32 PM
KenHorse's Avatar
KenHorse
From: I live my life by 2 rules. 1) Never share everything you know. 2)
St. Jude Donor '11-'12-'13, '16-'17-'18
FYI, matte black for comparison
Old Feb 22, 2019 | 07:35 PM
Slynky's Avatar
Slynky
LOL... you think there is a paint that resembles carbon flash?
Old Feb 22, 2019 | 07:36 PM
Slynky's Avatar
Slynky
Is the OEM stinger from GM matte or glossy?
Old Feb 22, 2019 | 07:41 PM
FLEXjs's Avatar
FLEXjs
Use painters tape to tape off the outer edges stinger stripe when you wax the car and don't wax it.
Old Feb 22, 2019 | 07:52 PM
Slynky's Avatar
Slynky
Yeah, admittedly, I didn't know if I should wax my ex's Mini stripes or not. Looks like I should have left them alone...
Old Feb 22, 2019 | 07:57 PM
Obe1 GS's Avatar
Obe1 GS
Both GM and aftermarket parts are commonly painted carbon flash metallic; same color as the louvers.
Old Feb 22, 2019 | 07:59 PM
sTz's Avatar
sTz
Painted stingers are certainly an option, but I’ve never had any issues with my OEM carbon flash vinyl stinger. It has a similar sheen as the other painted carbon flash pieces on the car.
Old Feb 22, 2019 | 08:18 PM
Slynky's Avatar
Slynky
GM and aftermarket parts referring to the vinyl stick-on...?
Old Feb 22, 2019 | 08:19 PM
Slynky's Avatar
Slynky
But you don't put a coat of wax on it...? You do like was mentioned before... taping it off, for example?
Old Feb 22, 2019 | 08:22 PM
NCJIMM's Avatar
NCJIMM
Default Carbon Flash Decal
I got a carbon flash decal from gm parts direct and blends perfect with hood vents
Carbon flash decal
Old Feb 22, 2019 | 08:28 PM
Slynky's Avatar
Slynky
Carbon flash decal
The vent still looks more glossy but it's close... does the OEM stinger sparkle any when the sun hits it right?
Old Feb 22, 2019 | 09:03 PM
Kevin A Jones's Avatar
Kevin A Jones
I have the OEM carbon flash stinger and it's glossy and you can see flakes sparkle in the light just like the carbon flash hood vent. I wax the stinger just like I do the blade silver and the hood vent it all looks very nice together.
Old Feb 22, 2019 | 09:41 PM
z06inVB's Avatar
z06inVB
I bought a piece of 3m 1080 wrap in black metallic (g212) for 22 dollars. Some 3m knifeless tape for 10 dollars. Then laid out the pattern set the wrap down and cut it. So total cost was 32 dollars and I had enough material left over to make a hash stripe as well.
To Stinger Questions
Here is the stinger that I had installed on my car. It was done at the same place that did the Xpel install.
Old Feb 22, 2019 | 09:43 PM
Slynky's Avatar
Slynky
Well, that is a fine-looking hood (and car) !
Old Feb 22, 2019 | 09:45 PM
Slynky's Avatar
Slynky
Nice! Looks like it sparkles in the black area, too.
