Winter storage
Old Mar 1, 2019 | 09:23 AM
JJB82's Avatar
JJB82
Default Winter storage
I have my car in a heated garage for the winter. I did not do anything to winterize it because every now and then I take the car out when the roads are clean just to get all the fluids circulating. However, with the weather being what it is by me it may be a little while until I can get the car out so I was thinking about backing it out of the garage and letting the car idle in my driveway. I know I have to get the engine up to full operating temperature, but I also heard that you should rev the engine. How many time should I actually rev it and how high on the tachometer should I be going?
Old Mar 1, 2019 | 09:28 AM
dvilin's Avatar
dvilin
If you are not going to be driving it for an extended time hook up the battery tender and leave it alone. Starting it idling it and revving the engine does way more harm than good.
Old Mar 1, 2019 | 09:29 AM
Mayor111's Avatar
Mayor111
Just so you know, it would actually be better to leave the car on a battery tender and NOT start the car at all till spring. I know you said that you bring the car up to temp - but there is no need to circulate the fluids... In addition, I wouldn't be revving the engine either.
Old Mar 1, 2019 | 09:34 AM
Elk's Avatar
Elk
Fully agreed.
Garaging the car for the winter is not storage, it is extended parking. Nothing special need be done other than to put a good charger on the battery, or take the battery out. Then leave the car alone. The highest wear on an engine occurs when the engine is cold and the oil has settled.
Plus, if you do not drive it you can remove liability and collision coverage and save a good bit of money on an insurance.
Old Mar 1, 2019 | 09:45 AM
Zjoe6's Avatar
Zjoe6
Lots of good posts here. Spot on.
Old Mar 1, 2019 | 10:09 AM
Patman's Avatar
Patman
As others have said, don't start it unless you're going to drive it, and at this point we are at the tail end of winter. Worst case scenario you might have to wait 6-8 more weeks before your roads are perfect but that's not a long period of time at all really. I know some people (crazy ones mind you!) that store their Corvettes for 6 months out of every year.
Old Mar 1, 2019 | 12:12 PM
orca1946's Avatar
orca1946
Just sitting in the driveway does not do anything for the trans either. Parked and on a tender is better .
Old Mar 1, 2019 | 12:17 PM
~Stingray's Avatar
~Stingray
St. Jude Donor '17, '19
1980, yes. 2014, no way. lol.
Old Mar 1, 2019 | 01:18 PM
Patman's Avatar
Patman
I think it's so crazy, one guy up here put his car away on October 1st! But yet we still had great driving weather right up until mid January here, so his car sat unused for 3.5 months for no logical reason.
Old Mar 1, 2019 | 08:28 PM
eseibel67's Avatar
eseibel67
I always love November for summer cars. Roads are clean and air is cold.
Old Mar 1, 2019 | 10:28 PM
The best thing to do has already been said - rather than just having the car sit at idle until it gets up to temp, just park it and hook it to a battery tender.
Old Mar 1, 2019 | 10:44 PM
Skid Row Joe's Avatar
Skid Row Joe
Worst thing you can do ^^^^ !!
If you cannot drive the car 20 to 30 minutes on the streets and highways, leave it be. You're doing more harm than good letting it idle/revving the engine.
Old Mar 2, 2019 | 10:01 AM
LIStingray's Avatar
LIStingray
Idling on the driveway, a dry sump car will never get up to full oil temperature, so as all above have said: don't do it.
Even if you are able to take the car out, if it is a Z51, GS , Z06 or ZR1, you really need to drive it for at least 20 miles to get everything fully warm and circulated. I am hoping to get my on the road in another few weeks - it has been salt city around here: my dark gray Jeep is now fully white.
Old Mar 6, 2019 | 10:07 AM
JJB82's Avatar
JJB82
Thanks for all the good advise. Looks like I’ll leave it in my garage for another few weeks (hopefully) it should warm up soon here. I was gonna take it out if the roads were free of sand and salt, but it doesn’t look like that’s going to happen for about 3 weeks now. If if it’s cold I’ll take it out without shutting it off until it’s back in the garage, but that’s only if the roads are clean and they are a mess now.
Old Mar 6, 2019 | 12:44 PM
Carvin's Avatar
Carvin
St. Jude Donor '15-'16
I know a guy who does this so he can have the car off the insurance from Oct to Apr. Seems like if you can afford a Vette you should be able afford the insurance.
Old Mar 6, 2019 | 01:36 PM
WalterMitty's Avatar
WalterMitty
1) At some point, won't sitting too long be bad for the tires? Like potentially flat spotting them? Or does this take years? I'm not talking about a massive, or exaggerated flat spot, but just sort of bad for the tires in general.
2) The issue I have is that whatever is use as my DD has to be able to run short errands. I see the note about letting it run for 20 miles or whatever, but I still want to take the car to the gym (3 miles way) or other short errands. There's really no way around this.
Old Mar 6, 2019 | 01:40 PM
Elk's Avatar
Elk
Radials do not flat-spot as old bias-ply tires did.
I have stored toy cars, and motorcycles, for the winter (four - five months) for many years and have never had an issue.
To Winter storage
Old Mar 6, 2019 | 02:20 PM
Widgeon5's Avatar
Widgeon5
[QUOTE=
2) The issue I have is that whatever is use as my DD has to be able to run short errands. I see the note about letting it run for 20 miles or whatever, but I still want to take the car to the gym (3 miles way) or other short errands. There's really no way around this.[/QUOTE]
Brief runs are not really an issue with your daily driver. It is prior to storage that it is important to drive it long enough to get fully up to temperature. In my own case, I will do this if it will be parked for even a week. Having said all this, if all your daily driving is very short trips, your car would still benefit from a full warm-up every few days to boil out condensation and resulting acids.
Old Mar 6, 2019 | 02:23 PM
Spitfire Mk1's Avatar
Spitfire Mk1
Formula 1
Agree. Also bc gas is so bad, i add stabilizer. No need to full tank for storage as it’s a closed system.
One of my cars sits for 6 plus months and I don’t use ethanol fuel as if can turn and clog injectors. So only use racing gas that has no ethanol.
Old Mar 6, 2019 | 03:16 PM
Patman's Avatar
Patman
True! And insurance is rather affordable on these cars, I only pay $100 CDN per month ($75 US). I just leave mine on all year round even though during the winter months there is that possibility of not being able to drive it for a few weeks at a time (I haven't been able to drive mine since January 12th this year)
