Blowing noise in cabin starting around 35 MPH and just gets louder!
Hey All! I just got my new 2019 Coupe. Coming out of a 2016. I wanted to run something by you to see if this is isolated or not. When I exceed 35 MPH, it starts sounding like a wind tunnel in the cabin! It’s tied in with the speed, not the ventilation system being on or off, that’s irrelevant. It sounds as if there’s a leak in the seal of the windshield in the center or right side. I’m not saying it is, but that’s what it sounds like. And it gets louder when I accelerate. It’ll sound like the ventilation system is turned up top 5 or 6 when you get up to 60 and that’s with everything turned completely off! My 2016 was perfectly fine. Anyone else experiencing this one?
It might actually be a leak around the windsheild. No big deal. Find the hole and as long as it's small, fix it. A great big gap means reset the windsheild.
CMEPCMEP (03-06-2019)
Take painters tape & tape around the windshield and see if the noise goes away, if not then at least you will know if the windshield is a problem.
Sounds like it's at the very front of the windshield, but I don't know how that can happen if it fits underneath the plastic drain pan the wipers come out of. I took a quick look and everything looks tight. I'm in Jersey and it's freezing here right now. The tape is a good idea when it gets a little warmer. The latches for the roof look secure. I wonder if anyone on the forum has an email address of a design engineer in Bowling Green? I wonder what their first hunch would be?
