OEM TOOLS No-Spill Funnel for C7 #87021
This is a nice tool when changing your oil. It twist locks on to the dry sump tank (just like the cap) and will not fall out when adding oil. Part # 87021
Will also fit wet sump C7 Corvettes.
Scientific Negotiator
Received 1,856 Likes
St. Jude Donor '07-'08-'10, '14
Wow NICE! Ordering one THANKS...
Received 19,719 Likes
'20-'21-'22-'23-'24
Looks like a very handy tool. Bookmarked it for future reference.
Received 5,295 Likes
I'd need one with a BIGGER top opening!
I haven't done oil change myself yet. Curious on why a regular funnel can't be use.
Of course, a regular funnel can be used.
This one is nice in that it screw directly into where you pour in the oil and the opening is accordingly large. This makes adding oil quick, easy, and mess free.
Just as nice it also fits BMW, for those of us who have both makes of car.
runner61627 (03-12-2019)
E-Ray, 3LZ, ZER, LIFT
Received 9,715 Likes
Was prepared with the same tools I used for 3 1/2 years on my 2014 Z51, a 6 point socket and long extension that fit under the oil cooler. Turns out the oil cooler in the Grand Sport is loner and the extension would not fit under the cooler. There is not enough space between the plug and cooler to fit a ratchet. Tried a 12 point box wrench and it was rounding the edges of the relatively "soft" drain plug hex head! It had what appeared to be a "red" strength thread locker! Had to improvise a way to grab the 6 point socket on the outside with a pipe wrench! Would be good to have a 6 point 15 mm box wrench. Somewhat unusual but they are available. Snap-On was like $35 but found one on Amazon for $13.
Don't really need it now as cleaned off what was a brown appearing tread locker residual! What is funny is the front plug came off with very little force. Too little, far under what the bolt torque would call for. Go figure.
ssmith512 (03-13-2019)
FWIW, assuming you have a new dry sump if you're changing at 500 miles. If so I found it was a bit difficult to get the side drain plug off of my Grand Sport.
Yep need a 6 sided socket or wrench like that. I also don't torque the plugs that tight or have I ever used thread locker on a drain plug. Can understand in manufacture BUT then why was the front plug so lose? I assume the "brown" stuff I found on that side plug was thread locker - just cleaned it off.
That is when I resorted to using my 6 point socket and turning it with a large pipe wrench to break the thread locker (or whatever that brown stuff was) lose!
Where there is a will there is a way!
wrecker3 (03-13-2019)
Added to cart!
JerryU (03-13-2019)
I've never torqued an oil plug, god knows how many oil changes I've done over the years and have never had a leaker or one that I couldn't remove easily.
