Which vendor has best price for Range AFM
It would be best to order directly from Range as then you will be sure u have the latest firmware and the best support
There are some vendors who are not supported dealers and for the few bucks saved might not be worth it if you have a problem with the device
Range ships fast
Dave
Range ships fast
Dave
Range ships fast
Dave
Range ships fast
Dave
Have you thought about a hand held tuner with a street tune and the AMF programmed into it? I talked to RPD and they indicated that it can be done with their devices as well as offer you a street tune if you provide your installed upgrades such as CAI, X Pipe, Headers, etc.
https://www.rdpstore.com/ I believe the part number when I called them was 40470.
krwunlv
krwunlv
Rebel Yell (03-12-2019)
If you are going to go with a hand held device I would go with a Diablo , no need for a custom tune to turn off AFM plus you can restore your original tune without leaving any trace that the tune file was modified
It's also a great scan tool and will allow you to modify a lot of the parameters in the tune yourself
It also will allow an upload of a custom time if you desire , it's very easy to use and if things go boom ... the diablo will see that the upload failed and automatically restore the original tune ...
Dave
Dave
Received 2,640 Likes
Range ships fast
Dave
Range ships fast
Dave
