Front inner tire wear - How can I prevent?
Zero toe not to much negative camber.
z51vett
Doug
z51vett
Doug
E-Ray, 3LZ, ZER, LIFT
Received 9,626 Likes
I got your ZO6 (03-18-2019)
The reason the toe spec is .1 degrees toed in, is because as the car moves forward, it has a natural tendency to push the tires outward.
So the idea is that the static tenth of a degree toe in, will be zero once the car is in motion.
