Where in the wide, wide world of sports is the pad sensor connector???
I know there's probably a thread on here that will tell me but I've found a ton of threads on the "Brakes Worn" message and not where to find the connector. I've got the car up, wheels off, and there's plenty of life left in the pads. Don't see a problem with the sensor so I want to check the connectors but for the life of me I can't find the connector. I'm going to go out and look again, try to trace the sensor wire back but if someone can point me to it I'd appreciate it. Help me save what's left of my sanity
Thanks,
Mike
Thanks,
Mike
Received 2,225 Likes
I could be wrong but I don't think there is an electrical signal just the old "squealer" system.
^^^ Same problem with resolution in this post.
https://www.corvetteforum.com/forums...post1599051001
Lol....yes it just squeals. There are little metal tabs that ride on the rotor whrn the pads wear down. There is nothing that interfaces to the electronics. Am I sure? Yes, i just swapped my pads to Powerstops this morning.
Mike
Well, called the dealer about the brakes and it's going in tomorrow. Also going to have them look at the headliner. It's detaching a bit in each of the corners...two birds, one stone. I'll update the brake situation when I get the car back.
Mike
Mike
Makes sense. The system appears to work the same as my brother's Porsche. So if desired you can defeat it by permanently connecting the two wires inside the connector. Of course these means you need to monitor pad wear the old fashion way: IE taking the wheels off and inspecting the pads. We did this modification to his Porsche because non OEM track pads don't come with the wires and thus you get the error message on track days.
Metal "squeakers" only work on standard iron rotors, the Z07 Carbon Ceramic Brakes are a whole different animal thus the reason they have sensors.
Received 2,051 Likes
St. Jude Donor '13
In theory, you are correct on shorting the wires. I believe there is some impedance there you may need to account for to prevent getting a message but maybe I'm misremembering that. In any event, the dealer has my car and it must be my lucky day because the intermittent message I've been getting actually came on just as I was talking to the service advisor. I don't think that's ever happened in my life. Be pretty hard for them to say they can't duplicate it now that they've seen it.
Car is back and so far, no service light. These are the tech comments:
Worn pad lamp is not currently lit. Inspected brake pads and they are not low. Found bulletin #PIC6061C and inspected harness connectors for evidence of damage. Scanned codes and found C0288 set in history. Inspected harness and found front passenger brake pad wear indicator harness to have made contact with wheel and rubbed through insulation. Found rear passenger harness misrouted; routed to correct position.
So, sounds like the harness was routed such that it rubbed. They replaced the bad harness. Also, they're ordering a new headliner. You can hear the adhesive grab when you push up on the corner but it lets go almost immediately.
Mike
Mike
The way they fold the fabric in the corners and glue that area doesn’t work well. I simply applied some spray adhesive in the corners and taped them tight with blue tape until they dried and all is good. Don’t be surprised if you get it back and it’s the same way. Try the spray adhesive, cheap and easy. Just my .02 for what it’s worth.
